Ipad2 display seems a bit fuzzy vs iPad1?
This is a discussion on Ipad2 display seems a bit fuzzy vs iPad1? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Originally Posted by DontUnderstandMyIpad Anandtech tested 2 wifi and 2 3g iPad 2's. So while the results where consistent for their 4 models, it may ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    STi
    STi is offline
    13833
    Sep 2010
    RI
    98
    Quote Originally Posted by DontUnderstandMyIpad
    So while the results where consistent for their 4 models, it may not hold true for all iPad's and it is not entirely clear, whether these display differences only existed in the early batch, or if Apple will continue selling wifi models with a lower brightness.
    But it is strange either way, as Apple sells the wifi and wifi+3g iPad's as identical, except for the 3g antenna.
    Here is the link:
    http://www.anandtech.com/show/4225/the-ipad-2-review/12
    Well that sux...I have a wifi unit and don't find this fair at all...Wonder if it's just early batch or this is the way it is....Maybe i should return mine towards the 30day return policy and hope for a brighter one! Mine seems to be slightly brighter than my 1 but don't want to be short changed cause i don't need 3g
    Sent from my iPad 2 using iPF
  3. #12
    iPad Master!
    20527
    Nov 2010
    404
    Quote Originally Posted by STi View Post
    Here is the link:
    The Apple iPad 2 Review - AnandTech :: Your Source for Hardware Analysis and News
    Its actually a pretty good strategy from Apple. They know that most reviewers are going to just get the 3g one so that they can review all aspects of the new iPad, so they use slightly better quality displays in them. Also, they gotta cut corners somewhere to hit that $499 price point, so using a slightly lower quality screen probably saved them a few dollars per unit.
    Obviously to prove this, its gotta be tested on a much larger scale, but I doubt anyone cares enough to do that.
  4. #13
    15433
    23 times
    Sep 2010
    782
    Quote Originally Posted by SporkLover View Post
    I did a sideby side comparo. In terms of Sharpness (fuzzy vs non fuzzy) they were equals. But the iPad 2 is definitely brighter and had slightly colder colors.
    I also compared side by side. Sharpness was identical, as were viewing angles. Colours were very similar but at lowest brightness up to 50%, the iPad 2 was less bright than the 1st gen. The iPad 2 was also warmer looking with a yellow tint. At full brightness, both seem equal and white level was almost the same - the iPad 2 was still slightly yellow though.
    The biggest issue is the whites & greys appear with a yellow cast but other colours look warmer and still fine. this may be a symptom from one of the screen suppliers.
  5. #14
    39481
    5 times
    447
    I've not seen any reports about this. Some members have reported on a difference in the brightness of the display, though. Are you comparing side-by-side? As you know, the two displays offer exactly the same resolution and pixel density, so it's difficult to know what could cause this effect but I wonder if a difference in brightness could make the two appear to have a different resolution?
    I don't have an Ipad 1 but I do have an Ipod Touch 2G and Iphone 3GS and I noticed the brightness in my Ipad 2 was low and had to turn it up.
    Perhaps Apple set it low to get the 10 hour charge?
  6. #15
    11919
    10 times
    Aug 2010
    Virginia, USA
    732
    I have both versions
    At least until I box up the iPad and send it to daughter #1. My iPad2's screen/resolution/clarity appear the same as that on my iPad. Have the same dozen movies and 900 plus photos on each and the same apps as well. The same appearance.
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
  1. iPad1 owners: Will you upgrade to iPad2?
    By Drag Bunt in forum Apple iPad Polls
    Last Post: 02-25-2013, 06:08 PM
  2. Ipad2/ ipad1
    By Sjwred in forum iPad General Discussions
    Last Post: 03-26-2011, 04:47 PM
  3. Will apps appear on iPad2 that won't run on iPad1?
    By Sowellca in forum iPad 2 Forum
    Last Post: 03-24-2011, 10:48 PM
  4. Need Advice: ipad1 vs ipad2
    By natedawg607 in forum iPad 2 Forum
    Last Post: 03-24-2011, 10:13 PM
  5. Will my iPad2 sync up with iPad1 data in iTunes
    By wahoowad in forum iPad 2 Forum
    Last Post: 03-09-2011, 04:45 PM
ipad 2 screen blurry
ipad 2 screen not sharp
ipad font blurry
ipad fuzzy screen
ipad screen is blurry
ipad screen red and fuzzy
ipad2 font blur
why is my ipad screen blurry
