GPS on Wifi only 16g
This is a discussion on GPS on Wifi only 16g within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Strange one here. My understanding is that the entry model 16g wifi option iPad 2 does not have GPS..... But mine has. I'm not talking ...
Results 1 to 10 of 10
    42263
    Leeds
    Question GPS on Wifi only 16g
    Strange one here.
    But mine has. I'm not talking when tethered or in fact connected to any network. Just been up the road and back with mine running the maps app ( sad I know ) and it 100% had my location all the way.
    Am I going mad????
    14699
    12 times
    Sep 2010
    Woodlands MB, Canada
    349
    GPS stands for Global Positioning System. GPS uses satellites orbiting the earh to determine position.... Note that GPS isn't the only positioning system there is.
    There is also what is known as WIFI positioning. (WPS).. That's what your iPad uses..The exact locaton of most Wifi spots have been recorded and compiled into a giant database... Your wifi iPad knows what wifi spots are active around you and it determines your position via triangulation. This is how Wifi only iPads can determine their position.
    It can be very accurate at times. (The more wifi spots around you, the more accurate it will be)... But if you head out in the country away from wifi spots, you won't be able to determine your position...
    GPS satellites cover the whole world, so a GPS iPad will work anywhere on the globe, but wifi positioning won't.
    40695
    3 times
    Atlanta, GA
    108
    You got lucky BigGreg.. they accidentally put a GPS in yours.. don't tell anyone!!
    42140
    7 times
    Columbus Ohio
    371
    My white 16gig wifi only tells my location as well. Even when not on wifi. The blue dot follows me in maps. I thought when apple said no GPS chip, they meant for Navigation.
    42140
    7 times
    Columbus Ohio
    371
    Sorry. It's not a blue dot when wifi is off, it's a grey dot. But it still follows me and even knows which direction I'm facing.
    Attached Thumbnails Attached Thumbnails GPS on Wifi only 16g-image-2896429554.png
    579 times
    Dayton, WA
    13,188
    I wonder if it is using your last known location and the gyroscope to estimate travel. Or, if it is turning on the Wifi in the background and getting a signal.
    Two things to test.
    One, go into Settings >> Wi-Fi, and make sure it is tuned off, not just without a connections.
    Power the iPad down, take it to a new location Power up and see if it finds you (again, with Wi-Fi turned off.)
    Note: To power down hold the power button for about three seconds until the Power Off slider appears, and slide it.
    37972
    138
    I bet you didn't have wifi off. It can still triangulate based on wifi signals without being connected.
    42140
    7 times
    Columbus Ohio
    371
    I did have wifi off. But when I powered off and then back on, it could not find my location.
    579 times
    Dayton, WA
    13,188
    Interesting.
    Like I said, I wonder if it could continue to use the gyroscope to estimate movement. The older inertial guidance systems used to work like that, and it would not surprise me if some of that technology was used to help keep the location accurate through temporary losses of the normal location signals.
    A long shot, but maybe. . .
    40617
    2 times
    Homeless
    198
    As soon as you try to use that Wifi only for any sort of real GPS mapping you will see how inaccurate it really is. It will not be able to guide you while driving as it will now know where you are in relationship to upcoming turns and it probably will not even be able to tell you what road you are on if there are other roads close by, like a road next to a freeway.
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. how turn wifi OFF/ON without the need to reenter wifi password
    By lse123 in forum iPad General Discussions
    Last Post: 07-08-2010, 11:06 PM
  3. Sold my 16gb wifi and wait for 32gb wifi is killing me
    By Ian B in forum iPad General Discussions
    Last Post: 06-29-2010, 06:19 PM
  4. Setting up Verizon Blackberry Tour Wifi Hotspot for Ipad Wifi
    By xlr8nflorida in forum iPad General Discussions
    Last Post: 06-14-2010, 11:09 PM
  5. Wifi vs 3G wifi speed/reception
    By CPMS in forum iPad General Discussions
    Last Post: 05-03-2010, 10:25 AM
does ipad1 have gps
gps to wifi
gps ? ????? 2 16 g
how do you check if a ipad has gps
how to tell if ipad has gps
how to tell if my ipad has gps
ipad 16g gps
ipad 2 16g wifi gps
ipad 2 wifi gps blackberry
ipad blue dot gps not following wifi only
ipad why 16g no gps
ipad wifi positiining
Tags for this Thread
