will 16gb be enough for me?
This is a discussion on will 16gb be enough for me? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have a 16gb black wi-fi on order--but after reading someone else's thread, I started to wonder if it's enough for what I want it ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    iPad Enthusiast!
    37128
    56
    I have a 16gb black wi-fi on order--but after reading someone else's thread, I started to wonder if it's enough for what I want it for. Someone else had said they use theirs for reading and had to delete books to download more.
    I plan on using my iPad for: (in no particular order)
    iTunes collection - (it's not a huge collection by any means, 500ish songs at just under 4gb)
    Games - I will probably download games that i'm guessing take a lot of memory? ram? idk. I'm looking at X-plane, driving, shooting, and random puzzle games
    APPS APPS APPS - I dont have a smartphone so every app i need will have to fit on the iPad2. I just dont want to have to go deleting stuff in order to fit new apps. Is there a way i can find out the storage required for each individual app?
    Web-Browsing - does having a ton of apps/games slow down internet load times? or are they independent of memory?
    Ik there have been tons of threads like this, but i really appreciate the responses. Thanks
    29345
    55 times
    Penarth, Wales, UK
    1,996
    16 gb sounds enough. most space is usually taken up with video and megga huge album collections. (ie, a typical 2 hour movie might set you back 1.5 gb)
    i personally think the more the better. at least 32. you'll regret it otherwise. you'll find you'll always fill it up with a lot more junk than you intend.
    and no, space (or lack of it) makes ZERO deference to web browsing times.
    iPad Ninja
    5787
    22 times
    Jun 2010
    2,282
    What you want to use it for would fit ok into 32 but expect 16 would be tight. Most apps and games are fairly small but videos run between 600mb to 1.5gb and if you're like me your photo albums grow rapidly. You have to be strong willed to stick within the 16gb
    Don't worry about your load times as they won't be affected by the number of apps you have.
    37868
    19
    Hey,
    I have an 8 GB iPhone 3G and I have never used up all of the GB's on it. Because of that I thought a 16GB iPad would be more than enough and I was going for the 16 GB. But then I started downloading stuff to put on my iPad so that I would have all the stuff organized and ready to be synced once I got the iPad. When I finished I had 18 GB of stuff (magazines, books, comic books, movies, apps) and that is not counting music and photos. So I decided I should go for the 32 GB and I've ordered a 32 GB and I'm really glad I did.
    It really depends on what you want the iPad for, some apps take a whole lot of space, alot of good games take up to 400 MB or more. Also, if you are considering buying interactive magazines like Wired or Project each issue takes around 400 to 500 MB.
    iPad Enthusiast!
    37128
    56
    yikes--that's a lot to consider. Thanks for all the opinions. I may cancel my order and upgrade to a 32gb. i guess that's more wait time for me...
    40695
    3 times
    Atlanta, GA
    108
    the 32gb is optimal, but you have to also consider if you have an iPhone, then you will likely use it differently than your iPad..
    Myself, for instance, I have no music on my iPad, because I have almost 12 gigs of music on my iPhone...
    I bought the 32gb iPad 2, and it's already filled with almost 20gb's of video, photos, apps, and other stuff... I figured if I put music on my iPad, it would just be a waste of space because I'm never realistically going to listen to music on my iPad itself.. I would likely always be using my iPhone to listen to music (in places like the gym, or while running outside).. and I'd likely be wearing headphones while doing so...
    or, i'd be streaming my iTunes library directly to my television or home theater system through my AppleTV, so I figured I would utilize the space on the iPad for something more relevant to the iPad, like video and photographs instead of music...
    38879
    rcower@gmail.com
    14
    When I buy a device that I can't add memory too (Ipad, Airbook) I buy it with the maximum. Spaces around me seem to attract clutter, and e-storage is no exception - it eventually fills up.
    iPad Enthusiast!
    41935
    Iowa
    33
    I keep roughly 500 -700 songs on my 16g. Couple of Movies, 10-15 apps and pictures and still have over 5g left. It really depends, do you want to sync/update your iPad daily/weekly, or have everything there and not worry about it. Is the extra $100 or so worth it to you? Everyone uses these differently, I would say if you have the $100 extra in budget, go for it. If your budget is tight, 16g will work, you just have to "clean house" a little more often.
    iPad Enthusiast!
    39271
    East Texas
    65
    I would agree with the above comment. since I bought a PogoPlug. I dont have to worry about the size of my devices. I ordered the 16gb iPad. I can stream my movie and music through my pogoplug remotely. Plus having 2 iPhone that I carry for work an personal i wouldn't need to put music on the pad. The PogoPlug is a pretty cool item.
    Sent from my iPhone 4 using iPF
    ~go BIG or go home~
    32532
    Feb 2011
    Belgium
    12
    For my point of view, 32Gbyte is a minimum for an iPad. Mine is a 64Gbyte and more than half are used. I've many apps and also some movies.
  1. Is 16gb enough?
    By southskier in forum iPad General Discussions
    Last Post: 11-17-2011, 01:39 PM
  2. Freespace on 16GB Wi.
    By Wollongong in forum New Member Introductions - Site Assistance
    Last Post: 10-31-2010, 03:26 PM
  3. Will 16gb Wi-Fi model be enough?
    By living2345 in forum iPad General Discussions
    Last Post: 02-10-2010, 12:34 PM
does a 16gb ipad have enough memory
does ipad 16gb have enough memory
ipad 4 16gb enough memory
is 16g too little memory for ipad
is 16gb ipad 4 enough
is 16gb ipad enough memory
is ipad2 16gb enough memory
will ipad 16gb be enough
