Volume rocker gone rogue!
This is a discussion on Volume rocker gone rogue! within the iPad 2 Forum forums, part of the Apple iPad Discussions category; For some reason does my volume rocker misbehave. It works fine for a while, but at some point it won't turn up the volume anymore, ...
Results 1 to 4 of 4
    iPad Guru
    30446
    11 times
    3,197
    For some reason does my volume rocker misbehave. It works fine for a while, but at some point it won't turn up the volume anymore, only down, so the iPad ends up being muted. The volume icon still shows in the center of the screen when pressing the up button, but had no effect.
    This has occurred multiple times with restarts in-between.
    Has anyone else come across this issue? Might it be an iOS fault, or a broken volume button?
    iPad 2 4.3.1.
    iPad Guru
    30446
    11 times
    3,197
    Sorry for double post, but I cannot add images when editing a post.
    Anyway, for some reason does the volume disappear completely, as shown below where the ball indicating system volume is gone.
    Attached Thumbnails Attached Thumbnails Volume rocker gone rogue!-image-2667425534.png
    iPad Guru
    30446
    11 times
    3,197
    Found the solution.
    The sound was getting transmitted via the HDMI cable to a screen whose speakers where turned off. The OS somehow overrides AirPlay and just sends the audio via HDMI, unless changed back every time the HDMI cable is connected.
    579 times
    Dayton, WA
    13,187
    Good to know. I might get one of those cables eventually.
  1. Problem with volume (down) control
    By jmarkhenrik in forum iPad General Discussions
    Last Post: 03-17-2013, 07:14 PM
  2. Volume control on iPad
    By TexasBlondie55 in forum New Member Introductions - Site Assistance
    Last Post: 02-18-2011, 06:33 PM
  3. How to get rid of 1 rogue e-mail?
    By PieterJ62 in forum iPad Help
    Last Post: 01-31-2011, 11:57 AM
  4. No volume avaliable
    By ipad2k2 in forum iPad FAQ
    Last Post: 01-20-2011, 02:28 PM
  5. app volume
    By meagain in forum iPad General Discussions
    Last Post: 01-14-2011, 02:56 PM
how can i turn off the sound effects icon on my ipad
how do i eliminate the sound effects icon on my ipad.
how do i get sound effects logo off my ipad
ipad can't adjust volume with button sound effect
ipad sound effects icon comes up when changing volume
ipad volume says sound effects when i change volume
my ipods volume is stuck on sound effects
volume control on ipad says sound effects
volume rocker on ipad
volume won't turn up ipad
volume won't turn up on ipad
when i press the bolume button on the i pad i comes up sound effect
