Imovie questions
This is a discussion on Imovie questions within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Ok I am trying to learn Imovie and I got 3 questions (I'll try to ask them as the best of my knowledge) 1) When ...
Results 1 to 10 of 12
    Banned
    8399
    Jun 2010
    104
    Imovie questions
    1) When you film a movie on Ipad, is it better to film it Portrait or Landscape?
    2) When I import a Movie in imovie how do you split frames
    EXEMPLE
    Lets say I have 2 sequence first sequence I have 5 frames and 2nd sequence I have 3 frames
    How do I take exemple Frame3 of squence 1 and send it as frame 2 of 2nd sequence
    While frame 1-2-4-5 of sequence 1 stays the same
    3) I have a problem with sounds
    When I add a sound and I wanna exemple enlarge the lengh i click on the sound and the little yellow circle shows, but when I click on the right circle to send it more right, it's the little red bar (that shows the location of the movie) that moves and no the yellow circle
    What do I do wrong?
    iPad Guru
    30446
    12 times
    3,196
    iMovie has a short manual, in the main page tap the question mark, located in the lower left corner, it will help you get started with the basic features, for example on how to split a video clip:
    With your project open, scroll the project timeline to position the playhead (the red vertical line) where you want to split a video clip.
    Tap to select the video clip (it becomes outlined in yellow), and swipe down over the playhead to split the clip.
    Regarding 1) I would say definitely shot in landscape mode, if you want to watch the movie on any kind of TV or widescreen monitor
    3) Hopefully someone else can help you out here
    iPad Addict
    27034
    5 times
    Dec 2010
    Gettysburg, Pa
    1,232
    3. when dragging the yellow circles it will only expand the video frames along with audio if included only to see more of the video frames it will not expand the overall length of movie/audio.
    38397
    3 times
    61
    Landscape for sure bc that will be final output. If u have a portrait scene it will not fill screen.
    I have found best if you cut your scenes in the picture app first. Take your sequence 1 and cut it by trimming to a new sequence and save as a new sequence. Then re open original and trim again for what will be sequence 2, save as new. Then open original again and make #3.
    Now in iMovie you can easily arrange all your pieces.
    Banned
    8399
    Jun 2010
    104
    Hi sorry for the bump
    I just did a Movie in Imovie and asked it to export to Itunes
    It says your movie has been sent to the share section of itunes under the name XXX
    But I can't find my movie lol where is that 'Share' section
    iPad Guru
    30446
    12 times
    3,196
    Quote Originally Posted by ratatapa
    -Connect the iPad to the PC
    -open iTunes and select iPad (under devices)
    -go to the Apps tab and scroll down
    -there is a list of apps, scroll down to iMovie and click on it. It will show your exported movie and you can copy it elsewhere.
    Banned
    8399
    Jun 2010
    104
    Ok next questions
    Here is a small useless video I made
    [ame]http://www.youtube.com/watch?v=UcFJRYJa1DE[/ame]
    1) I have 2 different videos here and you can see with 2 title
    But like my first video last like 20 secs but I dont want the title to show that 20sec but like 5-6 sec can I fix that?
    It's already at like Start but meh
    2) Can I modify the predefined themes or I'm stuck with it?
    3) The geolocation on Imovie is bad, all I can select is Montreal but my city is not montreal
    once again i'm stuck with it?
    15433
    23 times
    Sep 2010
    782
    For point 1), I'm not sure if there is a way of modifying themes - I don't believe you can but I am very new to iMovie. What I do is have a black picture, put that at the start of the video clip, set the duration for how lobe I require e.g. 3 seconds and add the title to this. It will then transition into the video clip without the title. Not perfect but one way of doing it.
    The other would be to split you video after say 5 seconds so you have 2 clips, the first with 5 seconds and the second with 15 seconds and then just add the title to the first section. The title should transition out but because it is the same video into itself, you may not notice the transition itself.
    Edit - Just tried the second method and it works fine as long as the transition is 0.0s long.
    iPad Addict
    27034
    5 times
    Dec 2010
    Gettysburg, Pa
    1,232
    Not sure why you're posting the vid when you flagged it as private. So all I see is a white box.
    15433
    23 times
    Sep 2010
    782
    Quote Originally Posted by ratatapa View Post
    Much better
    http://www.youtube.com/watch?v=iS7lGnQn9HU
    I need to find a 5sec Black screen to keep in my movie file
    Your videos are private so we can't see them. Can you make them public please?
    Also, you don't need a 5 sec video clip - just use a black picture (cover up lens and take a snap) and just use this image when required. You can drag the time line of an image to make it last as long as required i.e. 5 seconds.
  1. iMovie beginner questions
    By DontUnderstandMyIpad in forum iPad Apps
    Last Post: 03-31-2011, 08:34 AM
can't find imovie in itunes
how do i make a scene longer in imovie for ipad
how to trim a song on imovie from ipad
imovie ipad cut audio track
imovie questions
ipad imovie copy clip
make audio clip longer in ipad imovie
saved imovie in itunes but cant find
