Apple TV Inertnet Speed ?
This is a discussion on Apple TV Inertnet Speed ? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I wonder if my DSL signal is strong enough to get good use out of Apple TV. Netflix shows up good on my TV from ...
Results 1 to 6 of 6
    33347
    12 times
    Feb 2011
    Mississippi
    259
    I wonder if my DSL signal is strong enough to get good use out of Apple TV. Netflix shows up good on my TV from my iPad using the HDMI cable most of the time but YouTube videos usually take forever buffeting! What a pain. I use an app called Speed Test and i get about 5 Mbps as my download speed consistently.
    So any Apple TV users out there care to post your wireless speed results and how well things like Netflix and YouTube work?
    41512
    Denver
    76
    5 meg throughput is plenty for Netflix or Youtube. You probably have 7meg dsl service - check out YouTube - Broadcast Yourself.. Mabey do some tweaking to your wifi settings such as the channel / signal strength / mode / etc.
    I have ethernet to my jb apple tv 2, and it streams flawlessly - even hulu worked until they switched authentication servers.
    Some videos on youtube just dont stream well no matter what - I have 20/40meg dsl and still have issues w/certain videos. Netflix has been known to throttle their service to high-bandwith users also. Good luck
    Ipad3(jb), iphone5, iPod touch4g(jb), 3 AppleTV2's(jb), Hackintosh
    33347
    12 times
    Feb 2011
    Mississippi
    259
    Thanks for the reply. I have the channel set to auto. And the mode set to 145 Mbps for the 2.4GHz and 300 Mbps for the 5G. It is a dual band wireless netgear router. I didn't see how to adjust the other setting you mentioned.
    41512
    Denver
    76
    Ok, regarding your YouTube buffering issues - first the basics - do you buffer on a pc/laptop with Ethernet or just the iPad? Make sure you have the latest firmware on your router, powercycle your dsl modem, look for other wifi networks in range on the same channel (your channel is auto but you can manually change it somewhere in wireless setup) use a wifi scanner like wififofum to view them. My iPad 1 would occasionally seem very slow on my netgear 802.11n router - the fix would be to go to the wifi settings on the iPad, click on my wifi network, forget my network, and then reconnect to it - enter the password - and all was fast again. My router ended up dying and I got a wireless modem from qwest and have had no issues since, so it was prob the netgear.
    You can also on your iPad go to settings, general, reset, reset network settings, and then reconnect - keep us posted!
    41512
    Denver
    76
    Btw - appletv2 is awesome! Xbmc makes it a true powerhouse (jailbroken of course)
    33347
    12 times
    Feb 2011
    Mississippi
    259
    I did some checking and we have the best package that AT&T currently offers in our area which is 3-6 Mbps. So if I'm getting 5 Mbps then I'm getting about as much as I'm going to get. Good news is that AT&T is switching us to U-verse and will offer packages 6-12, 12-18, or 18-24 Mbps. I'm not sure when that will take place but hopefully before too long. Thanks for your help...
  1. Speed Test
    By oldertwin in forum iPad General Discussions
    Last Post: 02-21-2013, 03:09 AM
  2. The speed
    By supersteve1 in forum iPad 2 Forum
    Last Post: 03-14-2011, 08:53 AM
  3. tap-and-hold speed setting
    By garthmolyneux in forum iPad Help
    Last Post: 02-22-2011, 02:45 PM
  4. Speed of Ipad
    By darrenwis in forum iPad General Discussions
    Last Post: 02-22-2011, 07:46 AM
  5. Any speed improvements with 4.2?
    By DaveSt in forum iPad OS
    Last Post: 11-19-2010, 07:43 PM
apple tv download speed
apple tv dsl speed
apple tv internet speed
apple tv internet speed requirement
apple tv internet speed requirements
apple tv requirements internet speed
apple tv speed requirements
apple tv speed test
best internet speed for apple tv
speed test apple tv
speedtest apple tv
speedtest appletv
