Facetime
This is a discussion on Facetime within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Has anyone figured out how to get on Facetime I put in my Apple ID and password, and it says, "check network connection". We have ...
Results 1 to 10 of 18
Thread: Facetime
    37858
    Central Florida
    16
    Facetime
    Has anyone figured out how to get on Facetime I put in my Apple ID and password, and it says, "check network connection". We have WiFI and I get my mail and on the internet just fine. Can't figure out why Facetime won't accept me.
    iPad Addict
    35525
    24 times
    Feb 2011
    1,036
    My wife and I just start the app and select each other and it connects instantly. Do you have the person your calling added as a contact?
    I'm a proud F.A.R.M member. You can't choose F.A.R.M. F.A.R.M chooses you!
    37858
    Central Florida
    16
    Quote Originally Posted by 1million View Post
    No, I don't have anyone as a contact yet. Don't I have to log on first? That is where the problem is. I"ll keep trying. Thanks.
    iPad Addict
    35525
    24 times
    Feb 2011
    1,036
    For my wife and I it had us sign in then set up. It took a few minutes for set up and we were chatting. Try restarting the FaceTime app and see if that helps or the IPad itself. Also try restarting the WiFi on the IPad.
    46270
    A probable Fix
    Quote Originally Posted by Avista View Post
    Hello
    I got a new ipad 2 yesterday and have had issues exactly as you describe. Apple support guys were unable to help.
    I have now fixed this on my Ipad and would be interesting to see if this fixes for you.
    Go to Settings, Network, Wifi and select your wifi connection. Go to the settings of it by pressing the blue arrow next to it.
    Then in the DNS server list add , 8.8.8.8, 8.8.4.4 to the list.
    ( The comma is important to add to the existing IP address that you will have in there- the existing address is most likely your ADSL router IP address)
    This instantly fixed it for me and worked 1st time after.
    If it works for you i will post how i came to this solution.
    best regards
    19323
    11 times
    Nov 2010
    Palm Beaches
    337
    The best app i use called " Tango" and it uses your 3G connections to establish face time application. I seldom use the face time WIFI, however I use the Tango app to have face time with my wife during lunch time.
    Tango is a free app.
    JJK
    JJK is offline
    45436
    5 times
    Thailand
    389
    I have these DNS as well, but it did not do the trick for me. Everytime I try to sign in it gives me a time out error. On my Mac no problem. I tried as well to create a new Itunes account, but here as well no luck.
    19323
    11 times
    Nov 2010
    Palm Beaches
    337
    Why don't you tell us how you have come up with this solution prior to altering one's DNS.
    19323
    11 times
    Nov 2010
    Palm Beaches
    337
    in order for Face time to work well, both parties must have strong WIFI connectivities.
    39481
    5 times
    447
    Are you logged in using the same account as someone else on the network?
    Also try putting your user name and password in through the settings app under facetime.
  1. Facetime freezing?
    By Mark4777 in forum iPad 2 Forum
    Last Post: 04-26-2011, 11:30 AM
  2. Facetime problem
    By blueridge in forum iPad 2 Forum
    Last Post: 03-15-2011, 12:32 PM
  3. Replies: 5
    Last Post: 03-07-2011, 12:42 PM
  4. facetime! anyone know this video app?
    By sdjensen2 in forum iPad 2 Forum
    Last Post: 03-03-2011, 12:08 AM
  5. Facetime the the current iPad
    By Hal05154 in forum iPad General Discussions
    Last Post: 01-28-2011, 12:46 PM
cant sign in to facetime on ipad
cant sign to facetime
facetime saying check network connection
facetime won't sign in
facetime wont connect on ipad
ipad wont sign into facetime
my ipad 3 won't facetime
my ipad won't facetime
