Smart cover "cleaning" abilities
This is a discussion on Smart cover "cleaning" abilities within the iPad 2 Forum forums, part of the Apple iPad Discussions category; So we were all very skeptical when Steve jobs claimed that the new smart covers' microfiber side will clean the screen. And as I've used ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    iPad Enthusiast!
    37707
    fmmrz5@mail.missouri.edu
    57
    So we were all very skeptical when Steve jobs claimed that the new smart covers' microfiber side will clean the screen. And as I've used my black leather smart cover since the 14 th I can say it defiantly does....sort of
    What it does do is shuffle all the fingerprints into three vertical columns. Is makes sense because the smart cover is divided up into it's four folding columns.
    Has anyone else noticed this
    iPad Guru
    30446
    11 times
    3,197
    Yes, it does the same here. It would have been better, if the inner side of the SmartCover had a consistent height.
    iPad Enthusiast!
    37707
    57
    Totally. However I do take the cover off while rolled up and use one side to clean the screen. Like cleaning with a toblerone
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    Sacrilege! Toblerone's are not to be mocked.
    Hadn't noticed, but it does seem remarkably free of fingerprints despite the usage of the last twenty four hours. If it really is the cover then well done apple.
    40016
    Huntsville, AL
    55
    Interesting. I didn't get a smart cover because I wanted a folio type of case. I've been using a couple Smudgebuster optical cleaning cloths that I got free at a military trade show. Works great.
    iPad Enthusiast!
    37707
    57
    here is a quick shot of what im talking about. kind of annoying, but i have some microfiber cloths on order. I was thinking about using some polishing gloves i have at work (bar) to polish wine glasses.
    Attached Thumbnails Attached Thumbnails Smart cover "cleaning" abilities-189185_10100103472607020_15921057_50734158_7907475_n.jpg
    iPad Junkie!
    37021
    223
    It almost looks like there's something on the inside cover that's being deposited on the screen. I'm thinking of using a hand vac on my inside cover. I use the cleaning cloth that came with my flat screen t.v on the iPad - it does a great job, but I noticed that once the cover has been closed and reopened, there's specs of dust on the screen - or maybe specs of whatever material is used on the inside cover. Could be it's just shedding, as some fabrics will do for a while.
    iPad Guru
    30446
    11 times
    3,197
    That is a lot of dust.
    Which way do you fold the cover? I tend to fold it in half, so that the outside of the cover is always out, as a result very little dust comes onto the screen. The 3 lines are still visible, but much less.
    iPad Addict
    35525
    22 times
    Feb 2011
    1,038
    My wife has the pink Smart Cover and I have noticed how it cleans her screen. At first she didn't really care for the SC but now she likes it.
    I'm a proud F.A.R.M member. You can't choose F.A.R.M. F.A.R.M chooses you!
    iPad Enthusiast!
    37707
    57
    Yeah I fold it back so the leather is out but I find myself using it folded into the triangle a lot. It's great for holding it while in landscape view. Not seeing any dust persay mostly just fingerprints. Nothing a wipe down cant take care of
  1. Any other games like "Words with Friends" or "Pirate Battle?"
    By Lend27 in forum iPad General Discussions
    Last Post: 03-21-2012, 06:30 PM
  2. Replies: 9
    Last Post: 03-29-2011, 12:49 PM
  3. Replies: 0
    Last Post: 03-14-2011, 12:59 AM
  4. Replies: 0
    Last Post: 02-23-2011, 08:29 AM
clean ipad smart cover inside
clean smart case
does ipad smart cover clean screen
does smart cover clean screen
how do you clean apple smart cover
how do you clean ipad smart case inside
how to clean a smart case
how to clean ipad smart case
how to clean ipad smart case microfiber
how to clean ipad smart cover
how to clean smart case
smart cover cleaning
