Smart cover "cleaning" abilities
This is a discussion on Smart cover "cleaning" abilities within the iPad 2 Forum forums, part of the Apple iPad Discussions category; It's just that the spots in between the sections of the cover aren't touching the screen so it shuffles all the oils not the three ...
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
  1. #21
    iPad Enthusiast!
    37707
    fmmrz5@mail.missouri.edu
    57
    It's just that the spots in between the sections of the cover aren't touching the screen so it shuffles all the oils not the three columns. Unfortunately I don't think there would be a way to avoid this. Just diligent cleaning.
  3. #22
    iPad Junkie!
    37021
    223
    Lint be gone
    Quote Originally Posted by Bratan View Post
    Quote Originally Posted by 05GT
    That's alotta dust! I use the Smart Cover and it doesn't really seem to clean much.
    Not a dust, it's skin oil. I noticed it too. Looks like cover absorbes the oil and after a while starts to deposit it on the screen. Try cleanig the screen and then put cover back on. Lines would reappear. Anyone has any advice on how to clean microfiber on the cover?
    I fold my cover so that the microfiber is on the inside; the specks on my screen were lint shedding from the microfiber, not skin oil.
    Last night I used a lint roller on the microfiber. It picked up a fair amount of stuff. I then cleaned the screen and shut down the iPad for the night and this morning, low and behold, a spotless screen.
    Folding the cover so that the microfiber is always on the inside should alleviate the skin oil residue. A lint roller on the microfiber takes care of the lint and whatever other gunk may have attached to the fiber. Not sure if it will clean up any skin oil residue, but worth a try.
  4. #23
    iPad Guru
    30446
    12 times
    3,196
    Quote Originally Posted by Aspasia
    Keeping the microfiber on the inside is certainly a good idea. However, when you fold it to a triangle, it only holds securely when the microfiber is on the outside, otherwise the iPad falls backwards when touching it. Certainly not ideal.
  5. #24
    iPad Junkie!
    37021
    223
    Will keep that in mind - although I have to admit that during the six days I've had my iPad, it hasn't left my hands (or lap)!
  6. #25
    41086
    New York
    33
    Quote Originally Posted by Aspasia View Post
    Got it. On mine it seems mostly skin oil, because lightly wiping it doesn't remove streaks, I really have to wipe it hard to remove it. Yeah good point about folding cover. I usually fold it in two, it's actually easier to hold like this because it doesn't "hang"
  7. #26
    iPad Master!
    36745
    Boston
    346
    Quote Originally Posted by DontUnderstandMyIpad View Post
    You can fold the microfiber to the inside when using the cover as a typing stand. That's how I use it most of the time and it's very stable. It's only in the vertical viewing position that the microfiber needs to be folded to the outside for stability.
  8. #27
    iPad Junkie!
    3720
    May 2010
    178
    I was very skeptical too, but it actually does work really well. I get the columns too, but its a hundred times better than having a bunch of nasty fingerprints all over. In fact, looking at it now, you can't tell at all that there are the columns there if the screen is on, and even when its off, it is very faint. Other than that, the screen is as clean as it was when I bought it. I hate covers, but the Smart Cover is well worth the money.
    Also, I just realized that you can fold the cover over when you are using it and the end of the cover will "stick" magnetically to the other side of the iPad (the side with volume, mute, etc). It exposes the microfiber, but if I'm walking and holding it in one hand, it is nice to not have it dangle.
  9. #28
    58229
    May 2011
    How about the outside?
    How do you clean the outside of the cover?? I've heard some use an eraser to clean the outside of the cover, but i'm afraid that it'll create an uneven shade afterwards or if i do it repeatedly.
  10. #29
    iPad Master!
    36745
    Boston
    346
    Exclamation
    Only use a thick microfiber cleaning cloth to screen the screen. The cloth seems to absorb the oil with very light rubbing. Just gently swipe off any large grit or dirt before rubbing the screen.
    This is how I cleaned my original iPad for almost a year (3 or 4 times a day) and the screen was in perfect condition when I sold it.
  11. #30
    iPad Junkie!
    37021
    223
    Quote Originally Posted by teny5557 View Post
    A damp cloth containing a bit of a mild liquid soap will clean the outside cover nicely - just make sure to use another damp cloth to wipe off any soapy residue. If you have a stubborn stain, the Mr. Clean Magic Eraser works wonders.
  1. Any other games like "Words with Friends" or "Pirate Battle?"
    By Lend27 in forum iPad General Discussions
    Last Post: 03-21-2012, 06:30 PM
  2. Replies: 9
    Last Post: 03-29-2011, 12:49 PM
  3. Replies: 0
    Last Post: 03-14-2011, 12:59 AM
  4. Replies: 0
    Last Post: 02-23-2011, 08:29 AM
clean ipad smart cover
does smart cover clean screen
how to clean a smart case
how to clean ipad 3 smart case
how to clean ipad smart case
how to clean ipad smart cover
ipad smart cover clean screen
smart cover cleaning
