Is it possible to restore ipad to brand new without using itunes? I want to do this and try to resync fresh...
nevermind I found it...I apologize...
This is a discussion on Ipad restore NOT USING ITUNES within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Is it possible to restore ipad to brand new without using itunes? I want to do this and try to resync fresh... nevermind I found ...
Assuming the iPad is not jailbroken, you would go to general > reset > erase all content and settings, but even that is not a full restore. You can't truly fully restore an iPad without iTunes and since you MUST connect it to iTunes at some stage anyway, you are just as well using iTunes to restore the iPad by pressing the big "restore" button. That's what it's for!
thank you so much buti tried but i cant get it off the dfu screen the restore quits half-way in restore.
You need to give us more details. Tell us the error code / message which iTunes will show if it fails. This will help diagnose the problem.
Are you jailbroken?
no im not jb err: the ipad could not be restored. an unknown error occurred(1611)
