iPad battery app (timer/tracker)
This is a discussion on iPad battery app (timer/tracker) within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I noticed that iPad 2's battery life seems to be way under 10 hours with normal usage. This morning for example it went from 100% ...
Results 1 to 7 of 7
    41086
    New York
    33
    Question iPad battery app (timer/tracker)
    I noticed that iPad 2's battery life seems to be way under 10 hours with normal usage. This morning for example it went from 100% to 85% in about an hour. That's around 7 hours if drain is constant. I'd like a more precise way of recording battery usage, does anyone know of application that can time usage of the device (i.e. start counting when it's wakes up, and stop when it goes to sleep)?
    Banned
    10565
    21 times
    Jul 2010
    Va
    1,251
    Quote Originally Posted by Bratan
    Try out boost magic. Seems to be working very well for me and gives you a more accurate percentage of battery life. Also gives tips on how to improve battery life. It has a screen test to see if you have any dead pixels. Also shows the 3 charging stages the iPad goes thru. Just because u plug iPad up and chug to 100% doesn't mean it's exactly at the peak/top of it's charge. You will see what I'm talking about once u check this app out. I had the "Battery" app at first but this boost magic app is really great ;-)
    iPF Super Guru
    40746
    99 times
    NW Left Coast
    3,504
    Quote Originally Posted by Demandarin View Post
    Thanks for the tip about the Battery Boost Magic app. I've been extremely happy with our iPad's battery life, but being the geek that I am, having more info about these sorts of things is great...if not just fun. I'm going to try it out.
    For the OP...different apps and programs can drain the battery much faster than others. Graphic intense gaming, constant use of WiFi and/or 3G, those sorts of things take a lot more power than some of the more basic apps. That said, it's possible that there's a problem. If it continues I'd have a chat with Apple Support.
    41086
    New York
    33
    Thanks! I've tried Light version of Boost Magic, it seems a great app (especially for reconditioning battery), but doesn't really give me statistics what I want. It estimates run time for various tasks, but doesn't seem to log battery usage. I used to have an app (battery graph) like this in my Treo 650 long time ago I'll keep on looking, but thanks again for the suggestion!
    41086
    New York
    33
    Quote Originally Posted by richsadams View Post
    Yup, that's my plan, but I want to gather some solid data first before I call Apple. BTW mine is WiFi only.
    I've read various benchmark people done, and it seems that most of them are not real life scenarios, i.e. they turn on iPad and start watching movies, using apps non-stop until battery goes out.
    I want to do a better test: i.e. turn in on the morning to check e-mails, news, read a little in the train, watch an episode of a tv show, keep it off while I'm working, then turn it back on for commute to home to a play a game or two, etc.
    iPad Enthusiast!
    38911
    Ohio
    55
    Quote Originally Posted by Bratan View Post
    if it's first charge it doesn't equivocate...b/c you sync with computer, which kills battery and doesn't charge it...try charging it to 100% then let it charge another 30-45 mins...there's a reserve on the ipad I"m sure...there is on iphone 3gs and 4...(so it acutally goes to about 120 percent rather than 100)..notice it stays at 100 percent much much longer than after it dwindles to 90...
    41086
    New York
    33
    Quote Originally Posted by Cadena96 View Post
    True, Lithium-ion batteries don't discharge gradually...
    Anyway I think I found what I was looking for. Two apps: Battery Graph (just like the one I had for Palm) and MeinAkku (unfortunately it's in German and not very pretty). Both track on/off events and show graph over time
  1. First timer
    By Fifi1992 in forum New Member Introductions - Site Assistance
    Last Post: 03-03-2011, 03:16 PM
  2. iPad Apps Tracker?
    By DrJNAB in forum iPad General Discussions
    Last Post: 12-03-2010, 04:11 PM
  3. Camera Self-Timer Save iPad!
    By robertlc in forum iPad General Discussions
    Last Post: 08-24-2010, 12:25 PM
  4. Tracker case
    By alspad in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-22-2010, 02:12 PM
  5. Real-Time iPad Sales Tracker
    Last Post: 04-10-2010, 01:21 PM
battery test app for ipad
best battery app for ipad 2
how to recondition ipad battery
ipad app to keep track of which apps are draining battery
ipad battery test app
ipad battery timer
ipad track battery usage
