Results 1 to 8 of 8
    36307
    12
    Battery Charge Time and Depletion
    So the battery should last 10 hours, but,
    HOW LONG does it take to charge once it is fully depleted?
    Also, I've been told that you should let your battery run completely out at least once a month, then recharge. Since it will go into sleep if you are not using it, what do you run on it so it will stay on and run down the battery?
    116 times
    15,249
    If you want your iPad to stay on and not go to sleep
    'Settings', 'Autolock', 'Never' will keep it on all the time.
    116 times
    15,249
    Sorry, not my day today....
    'Settings', 'General', 'Autolock', 'Never'...
    iPad Guru
    30446
    11 times
    3,197
    Isn't it around 4am? At least that's the current time in the Scotland I live in :-)
    To run down the battery, either leave the iPad on, as Tim described above or just don't charge the iPad until the battery runs low.
    116 times
    15,249
    Indeed it is just after 4am - but a moderator's day is never over......
    36307
    12
    WOW - thanks for the QUICK responses.
    I realize I could just wait til the battery ran down over time, but I like to keep it at a full charge so I have plenty of battery time.
    So, I thought I should periodically FORCE the battery to run out.
    Is this right? Or should I just charge it back up every night?
    So, do I need to make the battery run all the way out or not?
    If I do, I can just make the changes above to not let it go to sleep.
    116 times
    15,249
    Here is Apple's official advice...
    Apple - Batteries - iPad
    iPad Guru
    30446
    11 times
    3,197
    You can just charge the iPad every night.
    The only reason to let the iPad's battery run low would be for the iPad to recalibrate the battery. The battery % is an approximation based on the voltage supplied by the battery, as the battery gets used the voltage slowly decreases. A used battery will even when fully charged, supply a lower voltage, so essentially this changes the voltage range in which the device can operate. When the device is uncalibrated, it is possible that a fully charged iPad shows less than 100%, because due to wear the battery cannot supply the voltage linked to 100%. So running the battery completely down simply tells the device in what voltage range it operates. But generally there is no need for this recalibration and should only be done, if you feel that the battery percentage is wrong.
  1. Battery Depletion Rate.
    By NLAlston in forum iPad General Discussions
    Last Post: 03-27-2011, 05:07 AM
  2. average battery time left
    By alternative_ in forum iPad Hacking
    Last Post: 12-09-2010, 12:11 AM
  3. battery charge and Frash
    By Dr.Gee in forum iPad Hacking
    Last Post: 08-17-2010, 05:37 PM
  4. Battery-when to charge?
    By CMFox in forum iPad Help
    Last Post: 06-22-2010, 09:24 AM
  5. Initial battery Charge?
    By Ellie in forum iPad General Discussions
    Last Post: 04-02-2010, 08:39 PM
average time to get a full charge on ipad
charging a tablet should you wait till depleted
how long charge battery depleted tablet
how long does it take ipad to deplete
how long for ipad to deplete charge
ipad 2 battery charging time
ipad 2 charge time
ipad 2 charging time
ipad charge depletion
n ipad 2 battery takes long time to charge
should you let your ipad battery run down
what is average length of time for i pad battery before need to recharge
