iTunes
This is a discussion on iTunes within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Do you really have to sink the iPad with ituns bEfore you can use the iPad? How long does it take to sink it if ...
Results 1 to 10 of 12
Thread: iTunes
    36407
    255
    iTunes
    Do you really have to sink the iPad with ituns bEfore you can use the iPad? How long does it take to sink it if this is true
    11830
    Aug 2010
    Matthews NC
    52
    Quote Originally Posted by Fifi1992 View Post
    Yes you will need to SYNC the device to iTunes in order to initialize the iPad.
    Should not take long depending on how much media you want to sync to it.
    If you have no movies, music, apps, photos, then it should take less than 10 minutes.
    All the best
    36407
    255
    Thx
    Quote Originally Posted by jthessin View Post
    All the best
    Thx so much
    39280
    Canada
    60
    The first time you sync the iPad with iTunes (after registration) does it go right into sync mode or do you get the chance to pick and choose what to sync? I have an iPod Touch that I regularly sync with iTunes (pictures, music, calendar, email, notes). Will iTunes default to what is set up to sync on my iPod Touch?
    iPad-2 White WiFi 64GB
    iPod Touch 3G 32GB
    37823
    479 times
    Cranbrook, Kent, UK
    15,265
    Quote Originally Posted by Tom P.
    You can pick and choose in the same way you can with Your Touch.
    29345
    49 times
    Penarth, Wales, UK
    1,935
    i havent used itunes in a long time (i'm an original Touch user), and i know you can manually individually sync (drag and drop) music and video to it. can you also individually pick and choose which apps to sync over as well (cos you couldnt used to originally)?
    11830
    Aug 2010
    Matthews NC
    52
    Quote Originally Posted by Tom P. View Post
    All you have to do IF it does start syncing is press the cancel or "X" in the info window at the top of the iTunes application.
    From there you go to the "Summary" tab and deselct the "Always sync contents when this ipad is connected.
    I think there is another way to do this in the settings section as well.
    36407
    255
    Thx
    Great info thx again
    579 times
    Dayton, WA
    13,188
    Also, if you want to prevent auto-syncing; open iTunes' preferences, the Devices tab, and check the box that says "Prevent iPods. . . from syncing automatically"
    From that point on you'll only sync when you click on the sync button, or choose it from a menu.
    iPad Junkie!
    3221
    Apr 2010
    106
    I also try to avoid ITunes as much as possible, since that Program often do things u dont want to ist always a risk that some Apps just dissapear for a reason u just dont see in the moment.
    Just keep auto-sync off and nothing will happen when u connect to itunes without doing anything.
    ITunes can be a pain, but still u should do a backup of your device from time to time (right click device name and "save") to not lose anything while doing a step in ITunes where u dont know what will happen.
    I really would never sync, but there iOS-Updates which you need to get, and theres the major problem of all.
  1. iPad vs iTunes on Windows and iTunes on Apple
    By lionman in forum iPad General Discussions
    Last Post: 11-21-2010, 02:57 PM
  2. Replies: 11
    Last Post: 09-23-2010, 06:29 PM
  3. Replies: 0
    Last Post: 06-18-2010, 09:31 PM
do i need itunes on my ipad2
do i need to update itunes to sink to ipad
do you have to sink ipad
do you need to sink an ipad
does ipad2 need to itunes
does my i pad2 have i tunes
how long does it take to download i tunes movies pn ipad 2
ipad2 itunes
is itunes really needed to use ipad 3
itunes for ipad2 ?
itunes preferences on ipad2
what does the ipad2 have to do with itunes?
