Leather or Polyurethane Smart Cover?
This is a discussion on Leather or Polyurethane Smart Cover? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Sweet Have used spirit based leather dyes in the past and they are very strong (ie. they penetrate well). A little goes a long way, ...
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 37 of 37
  1. #31
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    Sweet
    Have used spirit based leather dyes in the past and they are very strong (ie. they penetrate well). A little goes a long way, so it would be easy to refresh a scuffed leather if you can match the colour.
  3. #32
    iPad Master!
    36745
    Boston
    346
    Quote Originally Posted by tzimisce View Post
    Quote Originally Posted by Tarkio View Post
    Actually it doesn't come with a "bleeding" disclaimer, it says some that because it's dyed leather some color "may rub off." Just like has happened over time with every leather item I've ever owned. The fact that other companies don't admit this upfront is no reflection on Apple.
    I will have to disagree. I have been using and own many leather products for many years now, including messenger bags, belts, jackets, shoes, folio and journal covers and valets, and I have never had any problem with any of them in terms of the dye/pigment rubbing off nor have any of these products ever arrived with a warning or disclaimer about non-fast dye.
    Some of the pigments on the leather items have darkened over time through usage and exposure to sunlight, but that is a natural feature of the pigment and not considered a defect. A well-made leather product does not have its colours rub off or bleed onto other surfaces, whether dry or wet, as the dye treatment can be baked fast into the hide to prevent exactly this. At the prices that leather manufacturers charge, a buyer should expect a certain level of quality.
    You are lucky. Every briefcase/shoulder bag I have ever bought lost color from wear over time. And none of them came with the appropriate disclaimer.
    Show me a single leather Smart Case that has had any color rub off and I'll think it might be a problem. Until then it's just FUD.
  4. #33
    37165
    Minnesota
    363
    Quote Originally Posted by sanantoniotx View Post
    I can't decide which one I should get. It is my understanding that the leather feels nicer (I didn't really like the slick feeling of the Poly..) but I have also heard that it can rub off onto the iPad. Also, color wise I find the red Leather cover the most attractive.
    What is your experience with the covers?
    If you like RED, buy it. If price is a problem get the closest color you like and save $30.
    The biggest issue in my mind is the cover is the stand ... what ever color you want. The other issue is quick on and off. Otherwise who needs a cover. The magnets are just a slick way to store it on the iPAD2. Actually works to hang it from a refrigerator door if that turn us on.
    If you want protection from scratches, the netbook cases work nicely.
  5. #34
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    You are lucky. Every briefcase/shoulder bag I have ever bought lost color from wear over time. And none of them came with the appropriate disclaimer. Show me a single leather Smart Case that has had any color rub off and I'll think it might be a problem. Until then it's just FUD.
    Depends on what you mean by "lost colour": if it is fading from exposure or material abrasion, and part of normal wear and tear, then it's not a defect. I am thinking specifically of a fresh leather dye rubbing off (as per Apple's disclaimer) like the way fresh denim (e.g. jeans, jackets, etc) can and does rubs off - which should not happen with factory-produced leather.
    32GB WiFi
  6. #35
    iPad Master!
    36745
    Boston
    346
    I agree. But I've seen no sign of any color rubbing off on anything so this appears to be Apple protecting itself from any long- term repair based on normal wear. The time to complain is when any reports of premature wear actually surface. So far it's a total non-issue.
  7. #36
    iPad Junkie!
    38182
    ceritos, california
    114
    $70.00 is a lot for the leather cover. I went urethane
  8. #37
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    Well, if its a non-issue, then Apple's warning is absolutely disingenious because leather dyes can be made fast, and that "technology" (baking the dye in) has existed for centuries. I saw a hilarious thread (not intentionally, I'm sure) on Macrumors discussing exactly this issue, and the amount of self-professed knowledge swirling around in there could fit on the head of a pin.
    32GB WiFi
  1. can you use smart cover on ipad 1?
    By mikeos in forum iPad General Discussions
    Last Post: 06-29-2011, 06:55 PM
  2. What's your feeling on the Smart Cover, like it or not???
    By MuktownPat in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-12-2011, 11:16 PM
  3. Zagg and the Smart Cover
    By mx1 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-13-2011, 08:25 AM
  4. smart cover rubbing off?
    By sjleworthy in forum iPad 2 Forum
    Last Post: 03-11-2011, 03:52 PM
  5. Smart cover queston
    By Kendo in forum iPad 2 Forum
    Last Post: 03-05-2011, 07:18 PM
ipad smart cover leather vs polyurethane
leather or polyurethane
leather or polyurethane smart cover
polyurethane or leather
polyurethane or leather smart cover
polyurethane vs leather
polyurethane vs leather ipad
should i get the leather or poly ipad smart cover
smart case polyurethane or leather
smart cover polyurethane vs leather
what is polyurethane leather
which is better leather or polyurethane smart cover
Tags for this Thread
