My iPad2 won't charge to 100%
This is a discussion on My iPad2 won't charge to 100% within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I used my iPad2 down to 9% battery then put it on to charge with the wall charger not the usb. After 9 hours charging, ...
Results 1 to 5 of 5
    21489
    Nov 2010
    21
    I used my iPad2 down to 9% battery then put it on to charge with the wall charger not the usb. After 9 hours charging, it was holding at only 94%. I turned of all the notifications, location servives, wifi and 3G, etc while charging so theoretically nothing could be using power while recharging.
    I am guessing that 9 hours and only 94% means a bad battery?
    Has anyone else run into this when recharging the iPad2? I would appreciate any suggestions.
    Frank
    Banned
    10565
    16 times
    Jul 2010
    Va
    1,251
    It should have been 100% wagging b4 9 hrs. More like barely 2 hrs. I would take it back and get it exchanged. I'd tell them faulty battery not charging to 100% don't waste time as they will probaly try to give u some b.s. Reason to keep it longer. U still under the 2 week exchange or refund policy. aCT NOW! Lol
    579 times
    Dayton, WA
    13,188
    Or it could just be a calibration issue.
    Run the iPad until it shuts down by itself. Then put it back on the charger and see if it gets back to 100%. Give it a full 10 hours, just to be on the safe side.
    If that does not work, be certain to contact Apple.
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    Actually, just do a reset first before anything else. If the reset causes the software to recalibrate the power meter correctly to 100% (or at least higher than 94%), then you wouldn't have to worry about all the other steps.
    32GB WiFi
    21489
    Nov 2010
    21
    Thanks I will try that.
  1. How frequently do you charge?
    By DarkLordEnron in forum Apple iPad Polls
    Last Post: 09-30-2012, 10:15 AM
  2. When to charge?
    Last Post: 06-22-2010, 01:11 PM
  3. Battery-when to charge?
    By CMFox in forum iPad Help
    Last Post: 06-22-2010, 09:24 AM
  4. Does not charge from pc.
    By G.a.r.y in forum iPad General Discussions
    Last Post: 04-04-2010, 06:32 AM
  5. CHARGE - Gone?!?
    By iWags in forum iPad General Discussions
    Last Post: 03-31-2010, 10:58 PM
battery won't charge ipod2
ipad 2 wont charge to 100%
ipad not charging 100%
ipad not charging to 100%
ipad won't charge to 100
ipad won't charge to 100%
ipad wont charge to 100
ipad wont charge to 100%
ipad2 wont charge fully
my ipad wont charge to 100%
what causes ipad 4 to indicates only 94% charged?
what if the ipad doesnt charge 100%
