Battery problem with ipad2?
This is a discussion on Battery problem with ipad2? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; My ipad2 battery drains even when it is off. Does anyone else have this problem? I can charge it to 100% at night and by ...
Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 70
    1698
    Mar 2010
    New Orleans
    9
    My ipad2 battery drains even when it is off. Does anyone else have this problem? I can charge it to 100% at night and by morning it is down to 90% without even using it. I am using the smart cover to turn it on and off -- I have the setting for the cover on "ON".
    Fred.
    iPad Master!
    36745
    Boston
    346
    As long as you have wifi, bluetooth, and/or g3 turned on it's still using power. Charging overnight might be a better idea.
    1698
    Mar 2010
    New Orleans
    9
    I don't have bluetooth, g3 turned on. My ipad1 is the same configuration, but it never drained when off. Just curious about the ipad2 because it could drain completely eventually without being used at this rate.
    iPad Junkie!
    5092
    May 2010
    Vancouver
    216
    That's not right. You should bring it back to Apple and get them to look at it.
    39404
    new york
    9
    Quote Originally Posted by fredhatfield View Post
    Fred.
    I'm no expert but i would try shutting off the smart cover on / off function, because i don't think it's really completely powered off with that function on.
    It's obvious;y just in sleep mode thereby still drawing battery life.
    27282
    Dec 2010
    179
    Do you have a lot of push notifications turned on? Mine drains 10% over a few hours because of it.
    iPad Master!
    36745
    Boston
    346
    Quote Originally Posted by Macmutt View Post
    Fred.
    The iPad is always in sleep mode unless it's completely powered off by pressing and holding the physical power button on the side.
    39406
    California
    22
    Mine went from 100% to 65% charged sitting on the shelf, off, for 2 days.
    iPad Junkie!
    3221
    Apr 2010
    106
    Theres also possibility that, thanks to damn multitasking, some of your apps are still on the run, hit the home button twice, the apps now popping up on the bottom are apps still running and draining battery life. Push and hold these, like deleting normal apps you can close them and battery will life longer again.
    1698
    Mar 2010
    New Orleans
    9
    I took the ipad2 to the Apple store as suggested, but the best I could get from the geniuses there is that a 1% to 2% drain per hour during sleep is normal.
  1. Screen discoloration problem on ipad2
    By usamultimedia in forum iPad 2 Forum
    Last Post: 11-20-2011, 07:34 PM
  2. Battery problem ?
    By jimfastcar in forum iPad Help
    Last Post: 03-13-2011, 11:52 AM
  3. Battery problem
    By Tootall in forum iPad General Discussions
    Last Post: 01-25-2011, 04:04 PM
  4. iPad NOT CHARGING Battery Problem Fix
    Last Post: 01-22-2011, 01:56 PM
  5. Weird battery life problem
    By lowlife in forum iPad General Discussions
    Last Post: 06-09-2010, 04:20 AM
battery problems with ipad 2
ipad 2 battery drain when off
ipad 2 battery issue
ipad 2 battery issues
ipad 2 battery life issues
ipad 2 battery not holding charge
ipad 2 battery problems
ipad battery life problems
ipad battery problems
ipad2 battery problem
my ipad 2 is using lots of charge
problems with ipad 2 battery
Tags for this Thread
