Battery problem with ipad2?
This is a discussion on Battery problem with ipad2? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; When fully charged, it does seem to hang around 100% for a while which I think gives a false sense of longevity. When it starts ...
Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 41 to 50 of 70
  1. #41
    15433
    17 times
    Sep 2010
    771
    When fully charged, it does seem to hang around 100% for a while which I think gives a false sense of longevity. When it starts to drop a few percent, it may appear that battery usage is speeding up. As has been stated in previous replies - 10 hours use equates to 1% every 6 minutes but of course reviews have found battery life can last well over 10 hours under favourable circumstances and much less under stress. I think your figures seem fairly accurate. If you are on Safari, you are presumably on Wifi too which uses up battery. What is your screen brightness at? Are you only uses Safari or anything else? Is bluetooth on even if not connected to anything?
  3. #42
    43969
    Northern Virginia
    Mine works great...now!
    I decided to completely drain the battery and now it is working like it should. Once I had it completely drained, I charged it fully and it holds the charge very well and my battery life is wonderful.
  4. #43
    53711
    May 2011
    Philippines
    12
    Thumbs up
    Quote Originally Posted by donka View Post
    Thanks Donka and Eightythree. I guess i should not worry too much. I just thought my ipad 2 can last for like 2 days with minimal usage with just using the smart cover for sleep. Thanks for the tip @eightythree. Last question, while ipad is at sleep mode is it ok to drain like 2-4% for 6 hours while ipad is technically at sleep and smart cover is on? Thanks sooo much guys. Nice forum
    From Manila, Ph
  5. #44
    iPad Enthusiast!
    40841
    Louisville
    42
    Quote Originally Posted by pudongski View Post
    From Manila, Ph
    You're welcome....YMMV but yes you will see drain while in sleep mode because while sleeping the os has to use alittle power, although its minimum its still power consumption. Sleep isnt the same as a device that is completely off/shutdown which uses zero power (obviously)! So, yes that is normal.
  6. #45
    15433
    17 times
    Sep 2010
    771
    Try turning off the smart cover feature and see if you still get the same drain over 6 hours.
  7. #46
    53711
    May 2011
    Philippines
    12
    Is that suppose to drain quicker when the smart cover function is on? I am really sorry for my questions, i am very much new to ipad that's why i may ask questions u think isnt worth asking.
  8. #47
    16272
    Sep 2010
    Usa
    143
    I did find to make difference
  9. #48
    iPad Enthusiast!
    54286
    May 2011
    Chicopee
    33
    Quote Originally Posted by fredhatfield View Post
    My ipad2 battery drains even when it is off. Does anyone else have this problem? I can charge it to 100% at night and by morning it is down to 90% without even using it. I am using the smart cover to turn it on and off -- I have the setting for the cover on "ON".
    Fred.
    That don't sound right at all. I use mine all day, I have the brightness turned down greatly but it makes it last. You definitely need to take it to apple and have them check it out.
  10. #49
    1583
    50 times
    Mar 2010
    Oklahoma
    2,524
    I have heard that in a few cases, the smart cover can move during different activities, turning the iPad off and on. It could be that a cover is the problem in that case. However, most battery issues are due to not doing the proper exercising of the battery. If you do not drain it down on occassion, it will lose memory of the full battery capacity and needs to be retaught.
  11. #50
    43969
    Northern Virginia
    Post Mine was doing the same
    My did the same...I drained it completely, then recharged it fully. It works perfectly now. Give it a try!
    Quote Originally Posted by HerbalTBag View Post
    Fred.
  1. Screen discoloration problem on ipad2
    By usamultimedia in forum iPad 2 Forum
    Last Post: 11-20-2011, 07:34 PM
  2. Battery problem ?
    By jimfastcar in forum iPad Help
    Last Post: 03-13-2011, 11:52 AM
  3. Battery problem
    By Tootall in forum iPad General Discussions
    Last Post: 01-25-2011, 04:04 PM
  4. iPad NOT CHARGING Battery Problem Fix
    Last Post: 01-22-2011, 01:56 PM
  5. Weird battery life problem
    By lowlife in forum iPad General Discussions
    Last Post: 06-09-2010, 04:20 AM
ipad 2 battery drain when off
ipad 2 battery issue
ipad 2 battery issues
ipad 2 battery life issues
ipad 2 battery not holding charge
ipad 2 battery problems
ipad battery life issues
ipad battery life problems
ipad battery problems
ipad2 battery problem
my ipad 2 is using lots of charge
problems with ipad 2 battery
Tags for this Thread
