wi-fi help!
This is a discussion on wi-fi help! within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am about to purchase an ipad2 either in store or on ebay.. and i am just looking for the ipad 2 wifi only 16gb, ...
Results 1 to 5 of 5
Thread: wi-fi help!
    39217
    wi-fi help!
    I am about to purchase an ipad2 either in store or on ebay.. and i am just looking for the ipad 2 wifi only 16gb, my question is, will i be able to get wi-fi access right off the bat without having to do anything but turning it on? espesially if i order it off ebay? like do i need to pay for some sort of data plan? or what, mainly wondering so i can jailbreak and unlock it. Thanks much.
    iPad Junkie!
    3751
    May 2010
    Beaumont TX
    195
    Yeah after you plug it in to your computer to register it, you will be able to use it on your home wifi network or any wifi network.
    White 32GB Wifi iPad2
    Black 32GB iPhone 4
    2.0 GHz C2D MacBook
    1526 times
    Walla Walla, WA
    15,436
    You'll also need the latest version of iTunes running on that computer to activate the iPad. You can find it on Apple's site. Apple - iTunes - Everything you need to be entertained
    And you really only need to post this once. Just pick the forum that makes the most sense to you. Most of us read them all.
    7684
    Jun 2010
    112
    Your iPad will auto recognize any wifi available and attempt to connect. If it's an 'open' wifi when you will be connected right away. If the wifi has a password system or and acceptance of terms requirement then you will have to respond to that request before you will be connected to it. You can also connect to your cell phone if your cell phone is set up that way. I connect to my Droid X all of the time with my iPad if there are no other wifi connections available.
    11919
    10 times
    Aug 2010
    Virginia, USA
    732
    There is no data plan for WiFi
    Data plans relate to 3G. You will not have that access if you purchase a WiFi only pad.
    Why would you need to jailbreak it?
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
do i need a data plan for ipad2
does i-pad mini require a data plan to connect to wifi
does ipad 2 wi-fi 16g need a data plan?
does the ipad 2 wi-fi 16gb require a data package?
does the ipad2 require a data package plan
ipad 2 does not recognize wifi
ipad mini wifi only can be connected on a data plan
ipad2 detecting wifi
ipad2 will not recogize wifi password
mini i pad do u need data plan
