Do any of you use the Clear Ispot? and if you do, can you get it to work with the Ipad 2? I can connect to the Ispot but, when I try to browse a webpage, it keeps re-directing me to the Clear support site page. I tried updating the firmware, with no luck. The clear support is very unhelpful and do not have a clue.
It worked fine with my original Ipad.
LinkBack URL
About LinkBacks
