Accidental Orientation Lock
This is a discussion on Accidental Orientation Lock within the iPad 2 Forum forums, part of the Apple iPad Discussions category; When I got home yesterday my iPad 2 was locked to sideways orientation. No, it wasn't the mute switch. That feature was set to control ...
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By lawhawk
  • 1 Post By DontUnderstandMyIpad
Thread: Accidental Orientation Lock
    36381
    30 times
    Iowa
    22
    When I got home yesterday my iPad 2 was locked to sideways orientation. No, it wasn't the mute switch. That feature was set to control mute and just in case I switched it back and forth and it made no difference (both the setting and the actual switch). I thought maybe the accelerometer or the gyro was defective. I went into settings and did a reset of all settings, and that fixed it.
    Any idea what happened? Is there some orientation lock feature that you can activate accidentally?
    Mbwakali likes this.
    iPad Guru
    30446
    11 times
    3,197
    Yeah, you probably went a little overboard with doing a full reset.
    The orientation lock is found in the multitaskbar. To access it, press the Home-key twice, then scroll to the left. The button to the left of the audio controls and the hardware switch swap positions. So if you set the hardware switch as a mute key, this button next to the audio controls becomes the orientation lock and vice versa.
    Samanthas likes this.
    36381
    30 times
    Iowa
    22
    That was probably it. I still have a hard time believing I did that by accident but that is the likeliest explanation.
    39488
    Boston, MA
    Just had the same issue....
    ...and I was nowhere near that panel to enable the lock. Easy enough as a user to fix but does sound like a confirmed bug.
    34219
    Feb 2011
    Tucson, AZ
    57
    I had a similar issue last night, with my ipad 2 being stuck in one orientation, despite the orientation lock switch not being on. I fixed it by turning the device completely off (holding down the wake/sleep button) and turning it back on.
    iPad 3rd Gen. 64 GB WiFi+VZW 4G
    7800
    Jun 2010
    Oregon
    144
    The switch doesn't affect orientation anymore does it? Or did they change it back with 4.3?
    “It is a paradox that every dictator has climbed to power on the ladder of free speech. Immediately on attaining power each dictator has suppressed all free speech except his own.”
    iPad - 64G - WiFi - 3G
    iPad2 - 64G - WiFi - 3G
    34219
    Feb 2011
    Tucson, AZ
    57
    You can choose whether you want it to be an orientation lock or mute switch. Since I can just mute it but pressing down on the nearby down volume button, I switched it to orientation lock.
    41398
    Virginia
    Quote Originally Posted by lawhawk View Post
    Thanks for your post.
    My iPad 2 did the same thing. One minute it working, next minute it's locked in landscape. I researched every thing I could think of, it appears that this is a very new glitch, the only option I thought I had was to take it to the Apple store. Then I found your post and after reset, it worked. Another gremlin that appeared yesterday was the wifi stopped working. So with the new found "reset" button I did the same thing but reset only the wifi. That fixed it.
    116 times
    15,249
    Good to hear from you. You’ll find a whole bunch of iPad enthusiasts in this Forum who are only too willing to help other iPad owners and to hear of their experiences. Don’t be afraid to post any questions you may have or use the ‘Search’ button near the top of the Forum web page. I usually find I discover one new interesting and useful piece of information about my iPad every day - and often not even what I was looking for!!
    There do seem to be a few issues that the reset fixes - though some of them appear to have been cured by a 'bug' fix update to iOS from 3.2 to 3.2.1, which you can download and install if these problems persist.
    Hope to hear from you soon with your thoughts about the iPad.
    Have fun and enjoy your iPad
    If you don’t already have it you can download a copy of the iPad manual for free.
    Apple - Support - Manuals
    It’s free too.
    37972
    138
    Glitch. Mine did it once too. I am hoping that it won't happen again with the 4.3.1 upgrade.
    I remedied it with a power down/power up
  1. Get Orientation Lock Switch Back On iPad 4.2 and 4.2.1
    Last Post: 07-20-2011, 04:09 PM
  2. Screen orientation lock
    By Emodracer in forum iPad General Discussions
    Last Post: 01-25-2011, 07:27 PM
  3. Replies: 32
    Last Post: 12-05-2010, 12:45 PM
  4. Replies: 36
    Last Post: 10-27-2010, 10:49 PM
  5. Replies: 7
    Last Post: 09-16-2010, 09:33 PM
fix ipad gyroscope
how to fix ipad gyroscope
how to reset ipad gyroscope
how to unlock ipad gyroscope
ipad 2 orientation stuck
ipad gyro lock
ipad gyroscope
ipad gyroscope lock
ipad gyroscope settings
ipad locked sideways
ipad won't change orientation
orientation is locked ipad2
