Mobile me?
This is a discussion on Mobile me? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I signed up for the free trial of MobileMe and I don't think I like it. I used it to sync my Mac to my ...
Results 1 to 3 of 3
Thread: Mobile me?
    37501
    Virginia
    32
    Mobile me?
    I signed up for the free trial of MobileMe and I don't think I like it. I used it to sync my Mac to my IPad but then when I added calendar on my IPad the info would disappear from my IPad. So now I have set to just sync my e-mail. Will I screw up my stuff if I cancel MobileMe and just go back to syncing manually?
    38648
    Atlanta
    Mobil me
    I have been using mobilme for 2 years. It works fine when set up. One thing you might do is make sure that you are not using itunes to sync calendars or imail. Also do not use itunes to sync any data that mobil me can do. Go to your settings on your mac and select mobil me, Then select the sync tab and select what you want mobil me to sync to your ipad. then go to the advanced button and select it. Select your computer and then select reset sync data then set the arrow to point to your computer. This will then send anything from mobil me to your computer that you enter from the ipad.
    38648
    Atlanta
    Mobil me
    I have been using mobilme for 2 years. It works fine when set up. One thing you might do is make sure that you are not using itunes to sync calendars or imail. Also do not use itunes to sync any data that mobil me can do. Go to your settings on your mac and select mobil me, Then select the sync tab and select what you want mobil me to sync to your ipad. then go to the advanced button and select it. Select your computer and then select reset sync data then set the arrow to point to your computer. This will then send anything from mobil me to your computer that you enter from the ipad, and you ipad pointing to your computer.
  1. CMP Mobile and Frantic Ford are going Mobile!
    By NITROFC in forum Off-Topic
    Last Post: 01-30-2011, 07:54 PM
  2. Can not sign up for mobile me
    By PvtMatter in forum iPad General Discussions
    Last Post: 12-26-2010, 11:45 AM
  3. Replies: 1
    Last Post: 10-07-2010, 10:28 AM
  4. Mobile Me?
    By Twiddles in forum iPad General Discussions
    Last Post: 10-01-2010, 03:21 PM
how to cancel mobileme from my email
i don't want my ipad set on mobile
ipad2 setting for umobile
mobil.me
u mobile ipad 2 setting
umobile internet for ipad
umobile internet setting for ipad 2
