Noob questions about iPad 2
This is a discussion on Noob questions about iPad 2 within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi All, First, if this is not the place for these questions, please let me know. I have a 32/wifi-only/iPad 2 (no previous iPad experience). ...
Results 1 to 4 of 4
    38685
    Hi All,
    I have a iPhone 3GS and an iPhone 4.
    --It appears that the App store is laid-out completely differently for the iPad than for the iPhone. Why is that?
    --Is there a way to easily navigate the App store (a la iPhone?)? It sure is a lot less "friendly". (i.e. games aren't sub-divided; etc.)
    --Seems much more difficult to "find all", and then to sort by "free". Is there a tweak or something to make the App store more iPhony?
    --In general, is the App store (concept) primarily designed for iPhone apps, but adapted for iPad? or vice-versa? ...or neither...both stores optimized for each platform?
    --The iPad seems to charge very slowly compared to my iPhones. Is this to be expected?
    --Does the battery required "conditioning"? (i.e. drain, charge, drain, charge, etc.)
    --Is there a way to have the iPad recognize (and update) all my Apps to the HD iPad version (where applicable)?
    --If I synch all my iThings to the same computer, will it keep the versions seperated?
    --I have a new "N" router. My iPad lists my "normal" household wireless network, but also a "5-G" network? I've never seen the 5-G as and option before. Has the purchase of the iPad 2 somehow teleported me a few years into the future? What is this 5-G network, and will I create a mini-blackhole by using it?
    --Are there a handfull of suggested "must have" apps? (preferably free?). (Google search = nothing useful)
    Thanks in advance....I sure appreciate the insight.
    33545
    4 times
    Feb 2011
    tallahassee, fol
    200
    Hi there, I'm no expert. I have an iphone 3gs and original iPad. When I connected my iPad to my computer, it just recognized it as a new ipad, and asked me to name it. It put all my Iphone apps on my iPad, so you don't have to buy the apps twice. Just make sure your phone is up to date with your itunes acct on the computer.
    As for the IPad apps, usually when searching you should see two sections, one for iphone and one for Ipad. Several of the apps are for iphones, since they have been out for a while, but they will work on the iPad, you just have to increase the size, there is a button that will do that. Also, the iPad apps cost more : (
    There are a lot of free apps, just do a search for "free".
    Hope this helps.
    31877
    Feb 2011
    39
    Our wireless-N router is dual-band: 2.4Ghz and 5Ghz. Perhaps the 5-G you're seeing is really just the 5Ghz signal?
    Not as Lean, Not as Mean, Still a Marine.
    119 times
    15,248
    You comment on the iPad charging very slowly compared to your iPhone. Be sure only to use the specific iPad power adaptor to charge the iPad and not the iPhone unit.
    The iPhone unit charges at only 500 mA whereas the iPad charger is 2 A - or four times as much. Although using the iPhone charger won't 'harm' the iPad, it does charge it very slowly. Yes, you can use the iPad charger to charge the iPhone - it won't damage it. The extra 'capacity' of the iPad charger just relates to its capability - it won't try to 'force feed' the iPhone....
  1. Apple noob with a few questions
    By EUROCOM in forum iPad Apps
    Last Post: 02-05-2011, 11:17 AM
  2. Just bought an Ipad, some noob jailbreak questions
    By Runner in forum iPad Hacking
    Last Post: 01-26-2011, 12:48 AM
  3. Ipad NOOB ;)
    By Dannyboy85 in forum New Member Introductions - Site Assistance
    Last Post: 10-19-2010, 10:59 PM
  4. iPad Noob
    By cvg in forum New Member Introductions - Site Assistance
    Last Post: 08-31-2010, 01:54 PM
  5. Not really an iPad Noob!
    By tsatryan in forum New Member Introductions - Site Assistance
    Last Post: 07-13-2010, 03:39 PM
