Will an IPAD out live a Laptop under the same usage?
This is a discussion on Will an IPAD out live a Laptop under the same usage? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; While waiting for my ipad shipment a thought came to me? What kind of life span should one expect out of an IPAD? Lets say ...
Results 1 to 10 of 18
    36299
    19 times
    500
    What kind of life span should one expect out of an IPAD? Lets say with daily use for reading, some typing, a few games and heavy internet? Will an Ipad outlive a lap top.
    Does the battery hold up over a long time? I go through a laptops every two years, the screen hinge gets weak, power port breaks, keyboard keys become none responsive or it takes forever to boot. Does the IPAD follow the same life experience?
    7684
    Jun 2010
    112
    I've had my iPad original since last Jine. Every. Day I have been using it between 6-8 hours each day. So far there have been no issues with it's useable. I anticipate the same thing with my new iPad 2 when it arrives.
    iPad Junkie!
    38182
    ceritos, california
    114
    Quote Originally Posted by Rlarson_mn View Post
    Have you noticed any appreciable difference in battery life?
    15347
    Sep 2010
    Hawaii
    22
    Fewer moving parts, I would guess it would. Depends on the brand of laptop. I have an old PowerBook I bought in 1999 that still works fine although the battery is dead. Had a Dell Inspiron that lasted as long as the warranty and then the screen died in about 18 months. My experience is that any Apple product I've owned lasts longer than I want to use it. Usually takes about 5 years before I succumb to want for a newer product.
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    I've had some pretty long-lived laptops in my time - the oldest one I have now still working is 9 years old - so I wouldn't make any comparisons. I would say, though, that they don't make laptops now like they used to.
    32GB WiFi
    10170
    Jul 2010
    Morrow, Ga.
    114
    I would say the Ipad would last longer, especially battery life.
    iPad Guru
    30446
    11 times
    3,197
    From a hardware point of view does the iPad have very few obvious failure points, the Home button being the main one. So just looking at the technical side, it can be assumed that the iPad will outlast laptops, just because there are fewer parts that can break.
    Now, from the software side of view, I would assume that laptops outlast an iPad. Most laptops, even years old can be used the same way as today's laptops, as all the software will run on them, just a bit slower. But with the tablet market still being in it's infancy, apps getting released in two years time will most likely not run anymore on initial iPads.
    So even if the iPad will theoretically function longer than a laptop, I would imagine the software on the iPad being so limited compared to the iPad 3 or 4, that the time people use their device will be shorter for an iPad than for a laptop.
    The main point being, that I assume the iPad will still work in two years time, I just don't think that I will still want use it then. On the other-hand, I still use my three year old laptop, because all the software I use works on it just fine.
    epb
    epb is offline
    4438
    10 times
    May 2010
    Chicago, IL
    865
    As I see it, the chief issues are the batteries and the flash drive storage. The batteries aren't replaceable and will lose effectiveness over time. The flash storage has a limited number of read/write cycles and will eventually corrupt
    You had your entire life to prepare for today.
    7684
    Jun 2010
    112
    Quote Originally Posted by hoshnasi View Post
    I can truly say no I have not noticed any difference. I will say though that my usage of the unit has gone up drastically the longer that I used the unit. I keep finding more and more applications to use tht have limited my need to open up my netbook, notebook or desktop.
    iPad Enthusiast!
    36656
    90
    I'm expecting about 3 good years, then I plan to sell/upgrade... though I might do it sooner if the iPad 3 has a better camera. (!)
    I expect the device and battery to run for 5 years, that's how long my little gray powerbook 520c lasted before both of the batteries would not hold a charge.
    I do wish there was a way to replace iPad batteries...
    I had an imac desktop that lasted from 1998- 2008, I had to replace the monitor once in that time. In fact, the computer still works, it's in the closet, I ran in to software issues... I think apple stopped updating system software for that model... If not I'd still have it. My new (2008) silver imac will hopefully do 10 years too... though it has been getting much less use since the iPad came along!
    Desktop ~10 years
    Laptop/iPad ~5 years
    That's what I expect. As others have said with apple the product tends to keep working longer than one wants to use it... or until Apple stops updating the system software... and then you need to run something that runs only on the latest system... but can't since you can't upgrade. (grrrr)
    Though, after 10 years it was nice to have a new computer.
    Now keyboards? I have destroyed so many... it's a shame. I need to stop drinking things at my desk and spilling them I had a cheap 3-rd party keyboard that was waterproof and it spoiled me... apple keyboards die if you so much as say the word "water" in their presence.
  1. iPad Usage Statistics - How can I see them!?
    By SamJames1990 in forum iPad General Discussions
    Last Post: 09-01-2011, 09:26 PM
  2. Replies: 0
    Last Post: 11-12-2010, 03:35 AM
  3. iPad 3G Data Usage too high?
    By jalexsmith in forum iPad Help
    Last Post: 07-31-2010, 03:13 PM
  4. iPad Data Usage incorrect
    By MikesTooLz in forum iPad Carriers
    Last Post: 06-10-2010, 07:13 AM
  5. A wonderful usage scenario for ipad
    By kichha in forum iPad General Discussions
    Last Post: 06-07-2010, 10:13 PM
ipad 2 life expectancy
ipad 2 lifespan
ipad 3 vs laptop
ipad anticipated life span
ipad life expectancy
ipad lifespan
laptop usage and lifespan statistics
laptop usage statistics
life expectancy of ipad
what is the lifespan of an ipad
what is the lifespan on an ipad
which should last longer ipad or laptop
