smart covers
This is a discussion on smart covers within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have just seen on another site that the smart covers arnt up to much, is it right that the magnets arnt very good, also ...
smart covers
I have just seen on another site that the smart covers arnt up to much, is it right that the magnets arnt very good, also they come off very easily, and that also cause there no cover on the back they can easily gets scratched.
has anybody else had similar problems with there covers, and do you also think that they are a rip off.
Or just one more point, is it true also they dont keep the screen clean, like what we were made to believe.
03-13-2011 10:18 AM
It doesn't clean the screen at all. I got a little cleaning with it by taking it off and rubbing the screen with it. I don't really intend to use it for cleaning the screen anyway. I'll just use the microfiber cloth that came ith it for that. The magnets seem to hold mine on pretty good.
I don't know if the invisible shield interferes with the magnet or not but I have noticed if I hold my iPad upside down sometimes the weight of the smart cover is too much for it's own magnets to hold and will come open. I would probably return mine but I already threw out the packaging. I forget the brand but I have seen another case that has the same style front cover but also has covers the back as well. I'm not sure if that one has stronger magnets in the front though. If it has good reviews I will probably switch to it.
iPad Master!
I don't have any shields on my iPad 2, but my black leather Smart Case snaps on and holds tightly. I can lift the iPad with the case and hinges hold, but I wouldn't recommend doing that very often.
The surface magnets are strong and hold the cover securely on mine.
It would be a good idea to also place a hardshell cover on the back that has corner reinforcement like the Mareware back cover. It works with the Smart cover and provides protection from back scratches, but more importantly protects the corners which are the most vulnerable to being scratched or having impact in a fall to a hard floor.
Originally Posted by
Chakatajaca
yes, I'd like to hear from anyone who has installed the invisible shield on the back of their iPad as well. I'd hate to spend the money if it hinders the smart cover from keeping a good grasp...
Posted from my
... Yeah Baby!
Why not just use the smart cover to protect the back of the IPad by turning it over when not using it. That way the smart cover will be on the surface and the back of the IPad will be face up? That's what I intend to do when my IPad and smart cover arrive.
I'm guessing most aftermarket covers will also have the magnet on them. Even if they don't why couldn't you buy a roll of the self-sticking thin magnet and put it on your case?
I reall y dont think that apple have really thought this through, i just carnt understand why they coulnt of made the smart cover fit all the way round, not only protecting the front, but the back has well, come on apple get a grip.
Rlarson_mn
Can you do that? It looks to me like you have to remove the cover completely when using the iPad, which is a downside for me - it makes it easier to misplace or leave somewhere..
You had your entire life to prepare for today.
supersteve1
The smart cover does what apple wants it to do. And, if you do think about it, it would be impossible to find another Cover and 2-position stand for the iPad for even a fraction of the price that the Smart Cover provides.
Don't get me wrong, I don't LIKE the smart cover, because it doesn't work for me and how I use it..
But the smart cover does some things and it does them in a decent way.
1) It protects the screen from getting scratches.
2) It provides a vertical stand
3) it provides a horizontal stand
4) It gives a heck of a lot of "grip" when on, either front or back, versus the naked iPad
5) It's better than NOTHING.
epb
Rlarson_mn
No, you don't have to remove it. The hinge allows it to fold completely over onto the back of the iPad. There's no reason you need to take the cover off for... well, anything.
- You may not post replies
- You may not edit your posts
Forum Rules
By Maura in forum Apple iPad News
Last Post: 03-21-2011, 09:11 AM
By veggiop in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 03-12-2011, 01:18 AM
By iPaciMac in forum iPad Wallpapers
Last Post: 02-23-2011, 09:43 AM
By Louisg in forum iPad General Discussions
Last Post: 06-22-2010, 12:13 AM
By rwilts in forum iPad Help
Last Post: 05-27-2010, 03:29 PM
best way to clean ipad smart cover
best way to clean protective cover for ipad
best way to clean smart cover
cleaning smartcase
how clean the leather smart covers
how to clean ipad leather smart cover
how to clean ipad smart cover
how to clean leather ipad cover
how to clean leather smart cover
ipad 2 smart cover vertical stand
ipad leather snap cover care
smart cover
