storage
This is a discussion on storage within the iPad 2 Forum forums, part of the Apple iPad Discussions category; thank you all for your very good points! i might satisfy my son's request for a 32 (after all he's the straight 'A', i wasn't...)...
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
Thread: storage
  1. #11
    38331
    France
    7
  3. #12
    21708
    Nov 2010
    7
    Another $100 jump...but isn't the 64gb more "economical" than the 32gb version? The jump from 16-32 is 16, while the jump from 32-64 is 32. All for the same $100 difference.
    I have 2 original iPads in my household: 64gb 3g and 32gb 3g. In terms of relsale (using eBay Instant Sale as a guide), the 64gb is now worth $149 more than the 32gb model.
  4. #13
    11919
    10 times
    Aug 2010
    Virginia, USA
    732
    Flash storage is greatly more expensive than
    harddrives. Greatly quicker, smaller physically, and cooler as well which is why they use it in iPads. They use it in MacBook Airs as well - check the price differences on upgrading the flash storage (only at time of purchase) on them!
    I don't share my iPad and have a bit more than 40 gig filled on my 64 gig storage. I need 64 gig but I read, have 3000 songs, a dozen or so videos and a thousand or so photos. If I shared this I would need a lot more than the available 64 gig option which is what I ordered on my iPad2.
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
  5. #14
    49911
    walla walla
    30 PIN to USB Hub to Flash Drives???
    Why can't I just use the 30 PIN to plug in 30PIN/USB adapter and then either use that to plug in a flash drive or plug it into a USB HUB that I have flash drives plugged into?
    Heck Flash drives are cheap and I can take a handful with me when traveling. Shouldn't that work?
  6. #15
    119 times
    15,248
    Quote Originally Posted by PhoneService View Post
    I'm afraid not. The iPad - if it's not jail broken - can only read movies and photos from a card plugged in via the optional camera connection kit. You cannot write to the card or read any general files. Indeed, during the latest iOS operating system update, the current drive capability of the 30-pin connector was reduced meaning that only a small number of flash drives will work even with a jail broken iPad.
    Sorry - flash drives don't help the iPad. The only storage you've got available to you is what's inside the iPad - cloud storage - such as Apple's MobileMe iDisk can be a 'sort of' solution, but basically there's nothing.
  7. #16
    49911
    walla walla
    iPad2 Storage
    Well, that doesn't seem very friendly now, does it? OK, then off to check out the Xoom, since the Galaxy and the other one look like junk...
    Dang,
    Greg
  8. #17
    iPad Enthusiast!
    12114
    Aug 2010
    31
    Dang,
    Greg
    It's not that it's a "friendly" issue. USB devices depend on the host for power, in most cases. The iPad, being a battery powered device, has limited power for USB uses and that is generally well below the power a drive uses. The motors pull a lot of power to spin the disks, more than is reasonable to ask an iPad to provide. Cards, on the other hand, take very little power, so they can be used with less impact.
    So, it's technology, not friendliness, that drives the situation.
  9. #18
    38516
    18 times
    Seattle
    555
    I'm not into the honeycomb devices but if your looking at the Galaxy you may also want to take a look at the Asus Transformer, that thing looks pretty slick and extended battery life with the additional keyboard. I'm not sure what the usb ports will power so you'll have to look into that.
  10. #19
    iPad Enthusiast!
    49747
    43
    Is it relatively easy to use iDisk from MobileMe to do cloud storage?
  11. #20
    iPad Guru
    30446
    12 times
    3,196
    Quote Originally Posted by htowngator
    Good question.
    It really depends on the apps you use.
    All Apple apps, such as Numbers/Pages work well with iDisk, but many third party apps have accepted Dropbox as a cloud standard. So you are actually better off getting a Dropbox account.
    That said, if the apps support iDisk, then it is simple to access the cloud files.
  1. Available storage space?
    By Ashwood11 in forum iPad FAQ
    Last Post: 01-24-2011, 09:57 PM
  2. iTunes storage on PC?
    By Langtang in forum Off-Topic
    Last Post: 01-18-2011, 08:52 AM
  3. User storage by app - how to see it?
    By BobR in forum iPad Help
    Last Post: 01-09-2011, 06:22 PM
  4. No Storage Space
    By USN_Retired in forum iPad Help
    Last Post: 09-27-2010, 11:52 PM
  5. Magazine Storage APP
    By MLB12 in forum iPad General Discussions
    Last Post: 06-26-2010, 03:01 AM
32gb ipad actual storage
how much storage is 32gb ipad
ipad 2 storage comparison
ipad actual storage
ipad capacity comparison
ipad storage capacity comparison
ipad storage comparison
storage
