smart cover rubbing off?
This is a discussion on smart cover rubbing off? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; sorry guys, did i hear rumours the new leather smart covers rub off or leave residue on the screen? or did i imagine it?...
Results 1 to 3 of 3
    29345
    55 times
    Penarth, Wales, UK
    1,996
    iPad Master!
    37167
    6 times
    256
    Just the leather. It's dyed leather, so some color will rub off for a while, especially if you get it wet. Shouldn't' get on the screen as the inside is a microfiber cloth.
    But that's just the nature of the beast with dyed leather. Shouldn't be any problem with the plastic ones.
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    Quote Originally Posted by dmaul1114
    Some kinds of leather dyes will rub off, for example, if you bought a DIY dye kit from the shops and applied it to a finished product, and cannot 'bake' the product to seal the dye in. However, if you are making a leather product in the factory and thus can dye and bake the leather *before* you stitch and produce the finished item, then there is absolutely no chance that the dye will rub off.
    If Apple are producing a leather item which inherently has non-fast dye, then I would question their production methods (maybe they are cutting corners in order to roll out product faster). I have been owning and using leather products for over twenty years, and have never had a single finished item where the dye ever 'came off'.
    32GB WiFi
  1. New smart cover and stylus
    By ajax in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-25-2011, 06:30 PM
  2. Smart Covers
    By veggiop in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-12-2011, 01:18 AM
  3. Replies: 34
    Last Post: 03-11-2011, 07:52 PM
  4. Smart cover queston
    By Kendo in forum iPad 2 Forum
    Last Post: 03-05-2011, 07:18 PM
does the leather smart cover rub off
ipad case is rubbing off in the screen
ipad leather smart cover rubs off
ipad smart cover leather red rub off
ipad smart cover lether dye off
ipad smart cover lether dye rub off
smart cover leather problems
smartcover error
