Speed on AT&T vs Verizon - Which is Faster?
This is a discussion on Speed on AT&T vs Verizon - Which is Faster? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Which is faster on the IPAD 2- AT&T or Verizon? I have both in my area and want to decide only on speed. WHICH IS ...
Results 1 to 7 of 7
    21489
    Nov 2010
    21
    Which is faster on the IPAD 2- AT&T or Verizon? I have both in my area and want to decide only on speed. WHICH IS FASTER?
    iPad Junkie!
    6966
    10 times
    Jun 2010
    Twin Cities
    103
    At&t
    iPad Master!
    3239
    Apr 2010
    Missouri
    404
    The reviews I've been reading with speed tests on the iphone 4 have always said AT&T was fastest. IF you don't live in the areas with terrible reception!!
    38314
    iPad Initial Speed Test
    If your looking for a short answer, AT&T's 3G network is definitely much faster. This is IF signal strength is sufficiently strong for both carriers. Verizon seems to get more coverage where there usually is none. If you had to settle between the two and signal strength is about the same, go with AT&T.
    AT&T's network is built on UMTS 3G which is faster. Verizon's is built on CDMA 3G. I've been using OOKLA to speed test the Verizon iPad 2 and my AT&T iPhone 4 simultaneously at numerous locations on 3G in the San Francisco Bay Area. The result? AT&T is a lot faster.
    I'm going to perform a more thorough test when the AT&T iPad 2 gets delivered and then I'll return the slower unit back to Apple. I'll tell you what I find.
    Brian
    Last edited by brianlee; 03-13-2011 at 01:58 AM. Reason: More writing, refinement in statements.
    36509
    160
    does Verizon charge a deposit
    37276
    28
    Quote Originally Posted by jhood2323
    No.
    36509
    160
    Dances to lady gaga lol in celebration
  1. Faster playback speed for videos
    By katieB in forum iPad Apps
    Last Post: 03-04-2012, 02:17 PM
  2. Any faster suggestion?
    By j0yful in forum iPad Help
    Last Post: 10-02-2010, 09:58 AM
  3. Which is faster 3G or Wifi?
    By SweetPoison in forum iPad Carriers
    Last Post: 09-04-2010, 07:32 PM
  4. Wi-Fi speed faster on Mobile than landline?
    By PCUK in forum iPad Help
    Last Post: 08-30-2010, 01:06 AM
  5. Which is faster? Wifi or 3G?
    Last Post: 06-22-2010, 12:03 PM
ipad 2 att vs verizon
ipad is fast on att then verizon
ipad verizon vs at&t speed
ipad3 at&t vs verizon
speed test bay area ipad 2 att vs verizon
verizon or at&t for ipad which faster
verizon vs at&t ipad3
verizon vs att ipad speed
whats faster verizon or at&t for ipad
which ipad is faster att or verizon
which ipad is faster on verizon or atat
which is faster verizon or at&t ipad 3g -4g
