ipad2 Case
This is a discussion on ipad2 Case within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I really like this case. But might be too expensive for me. Anyone have this one? Or where i might find a case similar? I ...
Results 1 to 10 of 14
Thread: ipad2 Case
    29861
    98
    ipad2 Case
    I guess a case with magnet is safe for the iPad since the Apple smart case has magnets.
    [ame]http://www.youtube.com/watch?v=z0v1nAHFu30[/ame]
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    Quote Originally Posted by tnbug View Post
    The smart case is designed to work (only) with iPad 2.
    This particular case was designed for iPad 1 - in fact, there are quite a number of other cases which use magnetic fasteners. However, I haven't seen or heard of any major issues on iPad 1 with magnetic cases - certainly not to the extent of problems seen on smaller devices like some smartphones.
    32GB WiFi
    37483
    130
    I am going to wait for about a month to get a case. I want something that is magnetic that also covers the back. I like the one the OP posted. I am sure there will be a slew of other cases to choose from in the very near future.
    36509
    160
    i need that full body guard for my 2 as it will be my cellphone/notebook/media device
    iPad Master!
    37167
    5 times
    256
    I'm just going with the smart cover (trying to decide between the gray/silver, blue or green) and just bought a 10.2" netbook neoprene sleeve (made by Tuari) for $12.99 at Target that I'll use to protect the back (and the whole thing) when chucking it in my brief case or back pack etc.
    10170
    Jul 2010
    Morrow, Ga.
    114
    That's just like the case I have for my Ipad. it's really nice because, you can't tell what's inside when it's closed. Some people thing it's just a notebook. I hope they make something like this for the Ipad 2.
    20011
    Nov 2010
    EU
    27
    For my iPad I found the best case was the one made by Apple.
    Apple iPad Case - Apple Store (U.S.)
    - simple
    - inexpensive
    - cleanable/washable exterior that is not expensive leather or something else you will worry about getting dirty or damaging
    - soft microfiber interior makes sure the iPad doesn't slip around and provides some impact resistence
    - folding flap provides an excellent stand for typing, etc.
    Unfortunately, the iPad2 is smaller in length (-1 mm) / breadth (-4 mm) and much thinner (-4.6 mm), so if it doesn't actually fall out of the iPad1 case it will at least slide around too much. Plus the rear camera is covered.
    I dearly hope Apple also produce an iPad2 case like the basic iPad1 case, with smaller dimensions and camera holes, etc., but in the same basic material/design.
    I'm not convinced the smart covers are a good idea, whilst being trendy and cool, the back is completely unprotected (although this may be a conscious decision on Apple's part to avoid heat build-up if using a closed case? - although my iPad1 doesn't have an issue).
    Plus there is the issue of travelling/carrying the iPad2 - the iPad1 basic case sort of conceals the device - it's completely covered so there is some protection against drops and scratching the back, and it also looks like a (paper) notebook so less tempting for people to steal. With the new covers the iPad is clearly visible and identifiable.
    I could go for a 3rd party case if Apple don't do the right thing, but it's just not the same, and usually much more expensive. In addition, they tend to look too glitzy (trying to promote themselves, I guess) and bulk the iPad up too much. Basically, the Apple case is perfect for iPad1 (IMHO), so I just hope there will be the same option for iPad2.
    But sucker that I am I will no doubt get the iPad2 fairly soon, regardless of case!
    iPad1 64GB WiFi
    iPad3 64GB WiFi
    (iPhone4, and wifey has an iPhone4S )
    iPad Master!
    37167
    5 times
    256
    Quote Originally Posted by iPad100 View Post
    I'd never just carry around the iPad. If I have gadgets with me that won't fit in a pocket then I have them in my attache bag or a back pack.
    As noted above, I just bought a netbook neoprene sleeve to keep it in when putting it in a bag to keep the back from getting scratched etc.
    I wasn't a big fan of the iPad one case. I like using the iPad without a case and it was too hard to put it in and out of. And I hated the way the edge stuck our rather than being flat--made it harder to hit the volume keys etc.
    37395
    DC Metro
    11
    I don't buy leather and it is a shame that a lot of cases seem to be leather. It looks like the Dodocase is leather free so I'm going to go with that.
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    Quote Originally Posted by leena View Post
    If you're looking for a Moleskine-style case, you should consider other vendors like Treegloo, Portenzo or Pad And Quill, who produce a far better product. DodoCase may have the most publicity, but its ongoing problems with durability and workmanship are also pretty well documented.
    32GB WiFi
  1. Will the iPad2 have swype?
    By CanopicJar in forum iPad General Discussions
    Last Post: 09-24-2012, 02:20 AM
  2. WSJ say... iPad2...
    By iFrog in forum iPad General Discussions
    Last Post: 04-03-2011, 04:23 PM
  3. Outlook on Ipad2
    By rmgetaway in forum iPad 2 Forum
    Last Post: 03-10-2011, 04:07 PM
  4. Should wait for iPad2?
    Last Post: 02-21-2011, 08:03 AM
any cases similar to oberon ipad
case
dodo case pan am
dodo case vs pad and quill vs portenza
dodo versus pad quill
dodocase vs pad and quill ipad 2
dodocase vs. pad and quill vs. portenzo
glitzy ipad2 covers
ipad2 case
pad and quill contega vs portenza
pad and quill vs portenzo
portenzo wing*
