two questions
This is a discussion on two questions within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I've developed a new problem that started about two updates ago. When playing 'words with friends' and leave a game to access a wordfinder and ...
Results 1 to 6 of 6
Thread: two questions
    78723
    Jul 2011
    two questions
    I've developed a new problem that started about two updates ago. When playing 'words with friends' and leave a game to access a wordfinder and want then to return to the game, it no longer goes directly back but displays the zynga page then after a few moments it goes back to the WWF page and may not always return to the same game.
    It's annoying. Has anyone experienced this problem and been able to cure it?
    question #2
    Does the battery charge last longer if you turn off the iPad with the power switch rather than simply closing the smartcover?
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Quote Originally Posted by retlas101 View Post
    question #2
    Let me just address the second question - first, you might want to check my post (#6) in THIS THREAD - also a 'battery monitor' app would be helpful - I've been using THIS ONE - below is a screenshot from my iPad w/ this app running - as you can see my battery had a 55% charge and 'standby' time (i.e. closing the smart cover) was nearly 400 hrs - I almost never turn off my iPad 2 (will do an occasional 'Restart' or 'Reset' if needed or just to 'clean out the cobwebs' ) - bottom line is that this is the least of your worry concerning battery drainage.
    296929
    Jul 2013
    United States
    15
    Quote Originally Posted by giradman View Post
    Attachment 46934
    I do the same thing ...BUT I am a little concerned if I may damage the battery in any way by leaving the charger turned on all night and sometimes most of the next day before I pick and use the ipad the next time...??
    Can I over charge the battery ??
    Bob G
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Quote Originally Posted by Bob327 View Post
    Can I over charge the battery ?? Bob G
    Hi Bob - Li-Ion battery technology is mature and safeguards are built into chargers (I have 4 different Li-Ion tools in my workshop) and into electronic devices that will prevent overcharging - this is not a concern; however, the battery should be used on a regular basis - checkout this Apple Support Article - indeed, the battery should be pretty much discharged once a month to allow the calibrating monitors to report the proper level of charge (see quote below from the bottom of that link) - Dave
    Use Your iPad Regularly
    For proper reporting of the battery’s state of charge, be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down).
    228327
    13 times
    Jul 2012
    175
    Quote Originally Posted by grantbbee View Post
    No. As giradman explained, the battery will not be damaged if left charging overnight.
    Moderator
    235421
    616 times
    Aug 2012
    Adelaide, South Australia
    3,654
    Bob G
    Hi Bob, there is no need for concern, as this Apple heavy explains:
    http://9to5mac.com/2012/03/27/apple-...ing-non-issue/
    Regards, Andrew
    Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Check out the rules~ http://www.ipadforums.net/forum-rule...ease-read.html
    iPad3 64gig black, much unused PC Win 8.1 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
  1. New and some questions!
    By kittie in forum New Member Introductions - Site Assistance
    Last Post: 10-17-2012, 04:16 PM
  2. GPS questions
    By FlavioSousa in forum iPad Apps
    Last Post: 08-30-2012, 09:02 AM
  3. 2 Questions
    By Taylor263621 in forum iPad Hacking
    Last Post: 03-08-2011, 01:14 PM
  4. A few questions
    By Dafe1er in forum iPad Hacking
    Last Post: 08-08-2010, 06:02 PM
  5. help with a few questions please
    By ayshf_j in forum iPad General Discussions
    Last Post: 07-20-2010, 07:00 AM
