Problems with sound on the lock screen
This is a discussion on Problems with sound on the lock screen within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello all I just bought a new iPad and I'm having some trouble with The sounds. Everything works fine as long as the iPad is ...
Results 1 to 3 of 3
    290531
    May 2013
    Hello all I just bought a new iPad and I'm having some trouble with The sounds. Everything works fine as long as the iPad is not locked. On the lock screen no alerts work. I checked all the forums and follow all the instructions about the mute switch and the settings and it still does not work. Is there something else I could be missing? All help is much appreciated!
    13576
    744 times
    Aug 2010
    Western NY state (USA)
    9,283
    Just to be sure - have you checked under the Notifications tab in your Settings app? Each app that gets notifications will be listed there. They'll be in two sections, one for those apps putting notifications in the Notification Center, one for all others.
    Tap on any one of the apps listed and a new tab will be opened. Look at the bottom the bottom of that new tab on the right. You will see a line titled "View In Lockscreen" with a button. Make sure that button is turned ON. Then, if you receive notifications, they will show on the lock screen.
    Do note this turning on process has to be done for every app you want to see in the lock screen. But, once they are all on, they'll stay on.
    And, right above the view line is another line for "Sounds." Make sure that is also on...
    Hopefully, this will help. If not, holler back and we'll take another shot at it.
    290531
    May 2013
    Hi, Thanks for your reply. I had checked all of those settings and it did not help. I was on the phone twice with apple support and they were stumped. Their last suggestion was to fire up Itunes and backup/restore the Ipad. They assure me that this will fix the problem. We will see...
  1. Delayed lock sound
    By justinboyer in forum iPad 3 Forum
    Last Post: 09-27-2012, 06:13 AM
  2. Replies: 12
    Last Post: 06-02-2012, 06:35 AM
  3. Keyboard click and lock sound
    By nmeamary in forum iPad Help
    Last Post: 12-17-2011, 09:44 PM
  4. Replies: 7
    Last Post: 07-19-2011, 12:56 PM
  5. post a screen shot of your home/lock screen.
    By Joker in forum iPad General Discussions
    Last Post: 08-27-2010, 08:28 PM
Tags for this Thread
