Wifi connect ability
This is a discussion on Wifi connect ability within the iPad 2 Forum forums, part of the Apple iPad Discussions category; We have 2 iPad 2's, purchased 1 week apart. One will connect to the home router while upstairs with no problem while the other will ...
Results 1 to 10 of 11
    181927
    Mar 2012
    So Cal
    5
    We have 2 iPad 2's, purchased 1 week apart. One will connect to the home router while upstairs with no problem while the other will not connect. Any ideas or help on this issue would be greatly appreciated.
    Jack
    181927
    Mar 2012
    So Cal
    5
    Neither will work. Thanks for the response.
    Jack
    85546
    577 times
    Aug 2011
    Edmonton AB Canada
    9,850
    Oh oh. Caught out. I didn't answer your question properly so I deleted my reply.
    OK. I'll put some thought into this and see if I can help. Have you tried rebooting the router. That can sometimes help.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
    181927
    Mar 2012
    So Cal
    5
    Yes, it's been rebooted several times.
    85546
    577 times
    Aug 2011
    Edmonton AB Canada
    9,850
    Does it work on different networks? Starbucks, McDonalds etc.
    181927
    Mar 2012
    So Cal
    5
    Yes. The issue is distance or minor obstructions such as a wall or floor.
    85546
    577 times
    Aug 2011
    Edmonton AB Canada
    9,850
    Well, unless you have a HUGE house, I would expect most wifi routers to be able to reach all parts.
    It might be worth looking at Apples's Airport Extreme to replace your router, and using an Airport Express as a signal booster. As a bonus, you could connect wireless speakers to the Express.
    I know this doesn't help, and I understand the frustration when one device works and another does not. I have one of those teenager things that lives in the basement and only surfaces when Netflix stops working, so I'm well used to this problem.
    I recently changed my network security from WEP to WPA2, because my son's iPad mini refused to connect, after months of working flawlessly. No problems since then. It could be worth trying that out.
    181927
    Mar 2012
    So Cal
    5
    Thanks, I'll give it a try.
    70740
    2 times
    Jun 2011
    Harrisburg, Pa
    77
    Did you try Settings, Reset, Reset network.
    214946
    3 times
    Jun 2012
    156
    I found that AppleAppStore does not offer a WIFI scanner which can tell you your WIFI router, access point, or hotspot signal strength.
    If you have a cheap Android tablet and install something like a wifi analyzer then you can see if the problem is with your router or something else.
    Ipads are very good at wifi performance so what you are experiencing I would guess that it is your router.
    There is a caveat with Android tablets. If you get one that is too cheap then the wifi won't work on those very well.
    We can hope that Apple allows someone to develop a wifi scanner app for ios.
  1. GPS ability with the iPad3 wifi only
    By dnaber in forum iPad 3 Forum
    Last Post: 10-26-2012, 06:26 AM
  2. Cant connect to my wifi
    By andw0o in forum iPad Help
    Last Post: 03-21-2012, 05:09 AM
  3. My wifi will not connect
    By mona1234 in forum iPad Help
    Last Post: 01-16-2012, 09:10 AM
  4. Cannot connect to wifi
    By Warriordawg31 in forum iPad Help
    Last Post: 11-13-2011, 06:19 PM
  5. Can't connect wifi
    By gaza111 in forum iPad Help
    Last Post: 05-27-2011, 11:03 PM
wi-fi connect-ability
