Help me
This is a discussion on Help me within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hey, Whenever i touch on the screen of the ipad every where on the screen get affected (example: when i try to open facebook i ...
Results 1 to 5 of 5
Thread: Help me
    289661
    May 2013
    Cairo, Egypt
    Help me
    Hey,
    Whenever i touch on the screen of the ipad every where on the screen get affected (example: when i try to open facebook i get music instead) all of this happen while it's charging and touching material like feather, glass, rubber, etc....
    any help please
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Hi Hamza - welcome to the forum!
    I have no idea why your iPad is behaving as describe, but please try the second & third maneuvers suggested below - if not helpful, then post back here for further advise - good luck!
    When an app (or several) are misbehaving, I usually go through the following steps:
    1. Force Close - open the multi-tasking bar (double tap the 'home buttom' or use multi-gesturing and swipe up); press & hold an app until all begin to 'jiggle'; find the offending app(s) and press the 'red circle w/ minus sign' - return to the home screen & try again.
    2. Restart - press & hold the 'Sleep/Awake' (a.k.a. power) button until a red slider appears (may take a few seconds) - move the slider to turn off the iPad; then press & hold the same button until the Apple logo appears - wait for a restart.
    3. Reset - press & hold the 'Power' and 'Home' buttons simultaneously until the Apple logo appears - this may take a longer time, so have patience; the iPad will 're-boot' - NOTE that none of these maneuvers will alter your apps, files, or settings.
    289661
    May 2013
    Cairo, Egypt
    Quote Originally Posted by giradman View Post
    Thanks for your help, but it's not about apps miss behabving, because i already tried what you menteined.
    Thanks for your help.
    288937
    Apr 2013
    fairfax
    75
    Quote Originally Posted by hamza ahmed View Post
    Hey,
    any help please
    Something has remapped your icons to open other apps.
    I don't know if you jailbroke your ipad or if you have some 3rd party memory or systools
    If you're able to do so, And have performed backups, I suggest a reset if that doesn't work restore from a previous backup
    Great if you can use the iTunes backup and recovery
    Good luck
    289661
    May 2013
    Cairo, Egypt
    Quote Originally Posted by batty505 View Post
    Good luck
    I just knew what's my problem.
    I think there is some mess inside my ipad electricity.
