Unjailbreak iPad 2 running on ios 4.3.3 (8J2). Please help!
This is a discussion on Unjailbreak iPad 2 running on ios 4.3.3 (8J2). Please help! within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello, I am running an iPad 2 (32 GB-WiFi-3G) device with jailbroken IOS 4.3.3. I jailbroke it using by visiting 'jailbreakme' website but now I ...
Closed Thread
Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By Mickey330
Thread: Unjailbreak iPad 2 running on ios 4.3.3 (8J2). Please help!
    284528
    Mar 2013
    18
    Hello,
    I am running an iPad 2 (32 GB-WiFi-3G) device with jailbroken IOS 4.3.3. I jailbroke it using by visiting 'jailbreakme' website but now I want to undo it so that I can update to the latest version of IOS 6. Please tell me the correct and failpoof method for doing so because I don't want to kill My iPad with wrong procedures. Can you please explain it to me step by step. HELPPPPPP!!!!!!
    Also is it worth upgrading my iPad to IOS 6?? Please advice. Thanks..
    13576
    748 times
    Aug 2010
    Western NY state (USA)
    9,307
    Generally-speaking, the best way to "unjailbreak" your iPad so you can upgrade it to the latest iOS is to connect it to your iTunes and select the Restore button (after making a backup first). iTunes will do its magic and, when its done, your iPad will be stock and running iOS 6.1.2. Then, you can use the latest jail breaking tool (evasi0n, v1.5) to re-jailbreak it.
    Now, your iPad is on a very old iOS version, so this process may not work for you. If the simple restore I described doesn't work for you, try following the steps as outlined by my fellow moderator, f4780y, in this tutorial: TUTORIAL - Failsafe method to restore the current version of IOS
    If you follow all the steps exactly as written, you should end up with a stock iPad running the newest iOS. Then, you can re-jail break it if you wish.
    While a backup of your AppStore apps (and your data and preferences) should be fine to put back on the iPad with the new iOS 6.1.2, I strongly caution you against making or using a backup for your Cydia tweaks. iOS 4.x is, again, very old. So, I recommend writing down all the tweaks you have installed and then, after you have re-jail broken your iPad, put them back on one at a time to ensure they will work properly.
    Hopefully, the simple restore using iTunes will work for you. If not, then this tutorial will do it (please ensure you read through it and follow it exactly as written). If you run into any troubles, give us a shout and we'll be glad to help further. Good luck.
    284528
    Mar 2013
    18
    Thanks for the heads up!
    One more query though.
    I have cracked app on my ipad which I installed after downloading IPA files from the internet and I want to keep them. Will a normal iTunes restore work on them so that I can reinstall them again on my iPad after update and jailbreak.
    Thanks again....
    284567
    Mar 2013
    USA
    Alot of solutions are out there on google, but can anyone suggests me which really works?
    Thanks in advance!
    13576
    748 times
    Aug 2010
    9,307
    Quote Originally Posted by sen_ovung View Post
    Thanks again....
    Let's see, how to put this... Oh, I know!
    We will no longer assist you with your upgrade issue and questions because you, sir, are a dirty rotten pirate! So, we won't help you here. This forum does not condone or help pirates. Not only is piracy, and any discussion thereof, against this forum's rules, it's theft and thus illegal.
    This is the last piece of advice you will get: remove those stolen apps (and any piracy tools you may have that helped you STEAL those apps), and from now on - BUY your apps from the AppStore as honest folk do!
    This thread is closed.
    The OB and kidneyshot like this.
  1. Ughhhh....can't unjailbreak ipad
    By kami4565 in forum iPad Hacking
    Last Post: 02-27-2013, 08:01 PM
  2. Replies: 11
    Last Post: 02-10-2013, 01:18 AM
  3. Should I unjailbreak my iPad 3 for iOS 6?
    By Alex234 in forum iPad Hacking
    Last Post: 09-17-2012, 09:58 PM
  4. Unjailbreak
    By RudyL90 in forum iPad Hacking
    Last Post: 12-23-2010, 03:54 AM
how to unjailbreak and keep the downloaded apps on ipad2
how to unjailbreak ipad 2
how to update ipad ios from 4.3.3
how to upgrade from ios 4.3.3 to ios 6 on ipad 2
ios 4.3.3 8j2 para ipad 2
is there a website where i can un jail break my ipad 2
run app 6.1.2 on 4.3.3 ios
unjailbreak ios 4.3.3
unjailbreak ipad
unjailbreak ipad 2
unjailbreak ipad 4.3.3
unjailbreak ipad 4.3.3 cydia
