Battery
This is a discussion on Battery within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I was curious. How's your battery life since the new update? I really haven't noticed any difference....
Results 1 to 10 of 16
Thread: Battery
    232418
    5 times
    Jul 2012
    74
    280206
    Feb 2013
    42
    I havent noticed a difference. This thing still goes 12 hours to get to 2% on the battery. Amazing.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,924
    Quote Originally Posted by Frank77 View Post
    Well, as you likely already know, there have been update issues w/ the current releases of iOS concerning battery issues, so what version(s) are you talking about and what problems are you talking about - please, when posting a new thread, include some specifics - just saying -
    232418
    5 times
    Jul 2012
    74
    Quote Originally Posted by giradman View Post
    Hi and thanks for your suggestion Giradman. I'm referring to the new update 6.1.2. I heard there was some talk regarding battery issues with this new update and wanted to be aware. As I mentioned in my post, I've had NO problems whatsoever with the new update.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,924
    Hi Frank - thanks for your response - I'm on the 6.1.2 update also and have not notice much of a change, but there still seems to be some discussion over the topic - sorry about any misunderstanding - Dave
    283008
    Mar 2013
    46
    I noticed it a bit since i use my ipad for school and when i get home its usually 20-30% life now its 40%
    3638
    May 2010
    Warwick, RI
    124
    iPad 3, IOS 6.1.2. JAILBROKEN about a month. Starting 2 days ago I've been monitoring the battery performance. When I turn the iPad on I note the time and again when I turn it off.
    In 24 hours from a full charge and using the iPad less then 2 hours the battery is down to 42%. I started monitoring because after 48 hours from full charge with unknown usage (probably 2 hours or so), the battery had depleted to 10%. I also notice it takes much longer to fully charge. It used to go to a full charge in 6 hours or less now it takes 12 or more hours to a full charge.
    I don't recall ever having battery issues like this prior to the 6.1.2 upgrade.
    Any suggestions to getting the most out of the battery?
    232418
    5 times
    Jul 2012
    74
    Quote Originally Posted by jimt29 View Post
    I'm really not sure how to fix your problem jimt. Perhaps others will chime in with a fix. Good luck!
    167823
    15 times
    Feb 2012
    Brooklyn, New York
    317
    @jimt29, check your Cydia tweaks/apps compatibility. Incompatibilities are one of the major causes (if not the number 1 cause) of battery draining. Make sure that all your tweaks are compatible with iOS 6, and if they're not, remove them until they're updated for iOS 6 compatibility or use alternatives that are supported by iOS 6 until that happens.
    iPhone 4S White 16GB iOS 6.1.2 || iPad 2 (Black) 16GB WiFi iOS 6.1.2 || iPhone 5 (Slate)/iPhone 4S (Black) 64GB Latest Beta/Full iOS
    iPhone Forums Moderator
    3638
    May 2010
    Warwick, RI
    124
    Quote Originally Posted by willerz2 View Post
    Good call. That was the first thing I did. Found 1 conflict and remove the offender. I also shut off most notifications but still the problem persists.
    Thanks for weighing in.
  1. Battery
    By Navneet Nayak in forum iPad 1 Forum
    Last Post: 10-10-2012, 12:09 AM
  2. Battery
    By kluppy in forum iPad Help
    Last Post: 08-16-2012, 10:43 AM
  3. How often do u charge battery to save battery life
    By eddiethebhoy in forum iPad General Discussions
    Last Post: 04-24-2012, 04:29 PM
  4. Battery
    By Larrybe in forum iPad Help
    Last Post: 01-02-2011, 11:07 AM
battery
panic.plist
what 6.1.2tweaks cause battery drain
