A charging Issue
This is a discussion on A charging Issue within the iPad 2 Forum forums, part of the Apple iPad Discussions category; About the first week I got my Ipad 2 two My cat chewed my charging cable. She has a habbit of chewing small cables for ...
Results 1 to 10 of 16
    280734
    Feb 2013
    oklahoma
    26
    Unhappy A charging Issue
    About the first week I got my Ipad 2 two My cat chewed my charging cable. She has a habbit of chewing small cables for some reason. Anyway I went and bought a generic charging cable that was apple aproved and It has worked just find since I got it. The only draw back is its that it comes unplugged from the ipad often. I think I have used it for just under a year. Well this morning I was using it and every thing was fine I unplugged it for a bit and when I needed to charging it again I got the not charging thing poping up. I know that it means that its not getting enough power to charge something but I don;t know why all of a sudden its doing it. I even borrowed my mom's charging cord that came with her Ipad and its still doing the same thing. Its never been dropped or had any moisture poured on it or anything so Im not sure why all of a sudden its doing this. I don;t even use it that often usualy I will just watch a few movies on netflix or something and thats it. I know that when the screen is off it will charge but I would like to get it back to full charging power.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,924
    Hi and welcome to the forum!
    Well, being a 'generic' charger, the statement that 'it comes uplugged from the iPad often' is a little concerning, i.e. does it fit the charging dock correctly like the original Apple version and has it possibly caused damage to your device? Not sure, but if your replaced charger worked before, you might want to plug it into your mother's iPad - if it seems to charge correctly, then your iPad may be the issue? Just a thought - if so, you likely will need to visit an Apple store and obtain some advice. Good luck!
    iPad Wizard
    49745
    368 times
    6,584
    What generic cable has Apple approved? AFAIK, Apple doesn't approve generic cables. It allows brand name makers to make cords because they meet Apple standards, and cords shouldn't come unplugged unless there's something wrong.
    234775
    Aug 2012
    Long Island New York
    22
    A charging Issue
    A buddy of mine had the same problem bought a cheap Non Apple brand charger needless to say he went and bought an Apple Brand cable I'd say that's your problem without a doubt
    Chris
    Ipad 2
    1596
    164 times
    Mar 2010
    4,561
    A charging Issue
    I am sorry you have problems my answer is simple buy the correct charger and cable. If you buy tires for your car do you put low grade tires on it and expect it to last ....no..
    Cheers Colin,
    Brisbane Australia
    _____________________________
    iPad User Guide
    Forum Rules. Please Read.
    Hacking Section Rules
    iPad Wizard
    49745
    368 times
    6,584
    Quote Originally Posted by col.bris View Post
    I agree with that.
    I figure when you're dealing with anything electrical, cheap is not the main criteria. Even brand name chargers can turn into duds, but at least your chances are better, because if they cut corners they risk their business, brand name and any goodwill, as well as expose themselves to legal liability. And if their product sets my house on fire or ruins my devices, at least I have a shot at accountability. Good luck with that with a five dollar cable from eBay.
    280206
    Feb 2013
    42
    The off brand cables are only going to give you mixed results. You'll just have to bite the bullet and pay for the Apple brand cables/chargers. I'm considering upgrading to the 12 watt charger and a longer cable myself.
    280734
    Feb 2013
    oklahoma
    26
    There is one problme with your analogy. tires or anything for that matter just because something is name brand dosn;t mean its not just as good. Just because a tire is not a name brand dosen;t mean its low grade. Its the same kind of charger as the one that came with my ipad only its a diffren;t color and it has a longer cord It was made to fit Ipads and I phones. I did end up finding out the problme It was not the cord but the wall charger that actualy came with my Ipad that had the issue. NOt sure why it messed up but I was lucky and had a spare one.
    280734
    Feb 2013
    oklahoma
    26
    Quote Originally Posted by fb si View Post
    This cable has served me well for almost a year and I would defently buy another one just like it if given the chance. It was not the cable's doing as to why it was charging at its lowest charge setting I had a back up wall charger and tried it and it worked fine it was the charger that came with my Ipad that was the problme. I am a firm beliver that you are only paying for the name when you buy namebrand stuff and that as much as some people will disagree if the generic product is well made it works just as good as the name brand item.
    280734
    Feb 2013
    oklahoma
    26
    Quote Originally Posted by Kaykaykay View Post
    I agree with that.
    I didn't buy it on ebay atleast not stuff like that. I buy them from electronic stores like best buy which I belive is where I bought this one. It came in a accsessery package deal with my ipad case with like a car charger too. it just was not a Apple name it was something like logitect but don;t belive it was logitech its been almost a year so don;t remember the name exsactly.
  1. iPad Charging Issue
    By MrMazen in forum iPad 1 Forum
    Last Post: 11-12-2012, 09:20 AM
  2. Ipad charging issue
    By printmeitadam in forum iPad 2 Forum
    Last Post: 08-16-2012, 12:19 PM
  3. Charging Issue
    By jschlis in forum iPad 3 Forum
    Last Post: 08-14-2012, 08:06 AM
  4. Battery charging issue
    By ianb59 in forum iPad 3 Forum
    Last Post: 07-13-2012, 05:58 AM
  5. iPad2 charging issue
    By sivaram4110 in forum iPad 2 Forum
    Last Post: 03-20-2012, 07:41 PM
