Problem when starting Cydia...!?
This is a discussion on Problem when starting Cydia...!? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; when I open Cydia on my ipad2, it shows below 3 messages in red and after that nothing works in cydia: x. wow, you exceeded ...
Results 1 to 6 of 6
    125778
    Nov 2011
    Kabul - Afghanistan
    40
    x. wow, you exceeded the number of package names this APT is capable of.
    x. problem with mergelist /var/lib/apt/lists/apt.thebigboss.org_repofiles_cydia_dists_stable_ma in_binary-iphoneos-arm_packages
    x. the package lists or status file could not be parsed or opened.
    Anyone can help how to solve this problem?
    White 64GB 3G+WiFi iOS 6.1 iPad2 - jailbroken using evasi0n...!
    13576
    1445 times
    Aug 2010
    Western NY state (USA)
    11,052
    Close Cydia out, fully (via the Multitask bar) and then reopen Cydia. Go to the Changes tab and hit the Refresh button. See if that helps?
    If not, try closing Cydia again and then respring the iPad. Then, try the above again.
    125778
    Nov 2011
    Kabul - Afghanistan
    40
    I tried both but still the same problem... Reloading and same error messages...!
    Any other solution?
    125778
    Nov 2011
    Kabul - Afghanistan
    40
    Any other solution for this problem?
    13576
    1445 times
    Aug 2010
    11,052
    Have you tried removing some repos (sources)? You must have too many loaded for Cydia to handle. So, get rid of some, but make sure you don't deleted the five defaults:
    BigBoss
    Cydia/Telesphoro
    Dev Team
    Mod Myi
    ZoTTD & MacCity
    See if that helps...
    125778
    Nov 2011
    Kabul - Afghanistan
    40
    Excellent
    I removed some of the sources and problem solved
    Thank you very much Marylin
  1. cydia problem
    By MrMazen in forum iPad 1 Forum
    Last Post: 01-03-2013, 08:32 AM
  2. have problem starting my apps.
    By Jtavassol in forum iPad Help
    Last Post: 02-27-2012, 10:16 PM
  3. Cydia problem
    By ccohen6410 in forum iPad Hacking
    Last Post: 09-28-2011, 07:04 AM
  4. Problem starting ipad2
    By gregghalonen in forum iPad Help
    Last Post: 06-28-2011, 05:39 AM
  5. Cydia problem
    By lrg32 in forum iPad Hacking
    Last Post: 02-01-2011, 04:30 PM
/var/lib/apt/list/apt.modmyi.com
/var/lib/apt/lists/apt.modmyi.com
cydia problem with mergelist
cydia problem with mergelist /var/lib/apt/lists
cydia wow you have exceeded
problem with mergelist /var/lib/apt/lists/apt.modmyi.com
problem with mergelist/var/lib/apt/lists/apt.thebigboss.org repofiles
