iMessage trouble when tethered to phone
This is a discussion on iMessage trouble when tethered to phone within the iPad 2 Forum forums, part of the Apple iPad Discussions category; My trouble is relatively straightforward. I have an iPad 2 64gig wifi only. iMessage seems to work just fine when I'm connected to a wifi ...
Results 1 to 7 of 7
    135505
    2 times
    Dec 2011
    28
    My trouble is relatively straightforward. I have an iPad 2 64gig wifi only. iMessage seems to work just fine when I'm connected to a wifi signal. Any signal. The problem seems to occur when I'm tethered to my iPhone 3GS hotspot via Bluetooth. In this mode I can browse on safari, use any of my apps that require an Internet connection and send and receive email. What I cannot do is use iMessage. It will let you press the "send" tab, but eventually I get a red exclamation mark and the "Not Delivered" message under the text. I should point out that the problem started when I upgraded to 6.0, and today's 6.1 update did not fix the problem. I've been living with the problem for a while now, but it's getting really old now. I use AT&T as a carrier if that makes any difference. Please help.
    Moderator
    131244
    605 times
    Dec 2011
    Regina,Canada
    14,369
    Quote Originally Posted by Thescatterling
    Have you tried tethering via WiFi! instead of Bluetooth?
    135505
    2 times
    Dec 2011
    28
    I'm not sure what you mean. To tether the iPad to the personal hotspot broadcast by my phone I have to use bluetooth. The personal hotspot will automatically turn on the Bluetooth if you activate it and have neglected to turn the Bluetooth signal yourself. Can the phone put out a wifi signal? If so, I was unaware of it. Also, as I have stated, I have no problem connecting to the Internet with Safari, Facebook, YouTube, the email app or any of my other apps while tethered. There is a connection to the Internet. iMessage seems to be the only thing not functioning.
    275966
    Jan 2013
    Japan
    Hi there. Since you're using an iPhone 3GS, you can't tether via Wifi, only via USB and bluetooth.
    Refer to the following links for details:
    - AT&T Support Page: iPhone 3GS, can it be a wifi hotspot? or can it be... - AT&T Community Support
    - Apple Support Page: iOS: System requirements for Personal Hotspot
    As for your original issue, this is an issue with the current iOS implementation.
    - Macrumors (iMessage won't send messages on iPad via bluetooth tether - MacRumors Forums)
    If you skim through the forum, you'll find out that "iMessage just doesn't know to look for a server connection through bluetooth".
    I, like you, am also experiencing the same issue. I hoped that the latest update (6.1) would fix this issue, but alas, based on your post it hasn't yet.
    I hope apple fixes this issue ASAP. This is a minor nuisance but a nuisance none the less.
    ##(Sorry for the first 3 posts. The system wouldn't allow me to post anything with links unless I have 3 prior posts.)##
    135505
    2 times
    Dec 2011
    28
    Quote Originally Posted by onboardpibs
    Thanks.
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,239
    Quote Originally Posted by onboardpibs View Post
    We appreciate you trying to help, but also wish you not to post in this manner just to obtain the ability to post links.
    Forum Rules - Apple iPad Forum
    Thanks,
    Ski ~
    iPadforums Moderator | iPhoneForums Moderator
    135505
    2 times
    Dec 2011
    28
    So there is no fix for this at all? Is this a problem all iPads have when tethered via Bluetooth? Yes, it was a minor inconvenience when I thought I was just too dumb to fix it myself, but if the problem cannot be fixed it turns into a *** I'm getting p****d situation. It's absurd that they haven't fixed it.
  1. Replies: 19
    Last Post: 04-26-2013, 03:30 AM
  2. Replies: 2
    Last Post: 01-26-2012, 09:27 AM
  3. 5.0.1 and a tethered jb
    By nickcuban in forum iPad Hacking
    Last Post: 11-12-2011, 09:14 AM
  4. What is tethered /un-tethered?
    By Dolfanpete in forum iPad Hacking
    Last Post: 04-03-2011, 11:55 AM
  5. No Tethered Hulu.....***!!
    By gentlefury in forum iPad General Discussions
    Last Post: 07-17-2010, 07:37 PM
can i imessage with bluetooth on ipad 2
can i use bluetooth to send message via tethered ipad
cannot send imessage while tethering
imessage and tethered connection
imessage bluetooth tethering
imessage doesnt work on blue tooth tether
imessage ipad wifi only
imessage not working with bluetooth hotspot
tethered ipad wont imessage
when using hotspot does imessage still work
why does my ipad send imessage over wifi and not through hotspot?
