I want, to transfer music from my dropbox to iTunes or music.
Please help
This is a discussion on Help can't transfer music from dropbox within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I want, to transfer music from my dropbox to iTunes or music. Please help...
Please help
You cannot put music into your Music app on the iPad from Dropbox. At best, you can play the music or open it in a third party app. The only way to load music into the official/default Music app (on a stock device) is to use iTunes. Sorry.
Yeah if you add it to your iTunes library
After you have added the songs to iTunes and have connected your iPad to iTunes, are you on the Music app in iTunes? You have to verify that those songs are checked to sync over to the iPad. If you've don't have them in a playlist, you'll have to check them individually. If they are in a playlist that is already on your iPad - you should be able to sync the Music and so the new songs will be loaded when the playlist is updated).
Hopefully, that should do it.
