Syncro and reset
This is a discussion on Syncro and reset within the iPad 2 Forum forums, part of the Apple iPad Discussions category; When plugging my iPad 2 into my Mac yesterday, I got a message saying that is could not be synced due to an internal error. ...
Results 1 to 1 of 1
    160465
    Feb 2012
    11
    Syncro and reset
    When plugging my iPad 2 into my Mac yesterday, I got a message saying that is could not be synced due to an internal error. So I backed up and attempted a reset. All seemed to go well until I got to the restore. I chose the correct restore setting and it seemed ok until I got the message that the iPad would reappear in iTunes after it had restarted. But it didn't restart. The only way I could get it to turn on was using the start and home buttons together. Then after plugging back into the mac it reappeared but straight away asked if I wanted to restore as new or existing. I have gone through this several times with the same result.
    Is it going to be an Apple Shop visit, or is there an easy solution?
  1. Password reset is possible ?
    By acuaries in forum iPad Help
    Last Post: 03-20-2012, 10:40 AM
  2. reset problem!
    By Wingless in forum iPad General Discussions
    Last Post: 03-16-2012, 02:11 PM
  3. need help with movie syncro
    By el.vedo in forum iPad Help
    Last Post: 07-31-2011, 03:30 AM
  4. reset
    By numbar in forum iPad Help
    Last Post: 12-26-2010, 07:40 AM
  5. Time reset
    By kgb in forum iPad Help
    Last Post: 04-11-2010, 05:29 PM
