Radio alarm
This is a discussion on Radio alarm within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi My wife just upgraded and "donated" her ipad2 to me ! ! This is the first Apple device I ever owned I would like ...
Results 1 to 5 of 5
Thread: Radio alarm
    198684
    May 2012
    23
    Radio alarm
    Hi
    I would like to know if it is possible to set it up as a radio alarm ? Ideally I would like to set it to "wake up" at 6AM with BBC Radio 4.
    Thanks in advance
    LR
    205997
    May 2012
    nogales
    9
    Sure you can, there is plenty of radio alarms at app store.
    Regards
    198684
    May 2012
    23
    Thanks, I found an app in itunes, but sadly I think this Ipad is not compatible as it says it needs IOS 5.1
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Radio alarm
    What version of IOS are you running? You can find out in Settings > About.
    The version requirements stated in the app store are usually minimum requirements. They are not specific. In other words, that app is unlikely to be only for version 5.1. It is for all versions 5.1 and above, which hopefully applies to you.
    If you are running something before 5.1 then you should probably update the device unless you have a good reason not to want to (such as maintaining a jailbreak or an aversion to IOS 6).
    14699
    12 times
    Sep 2010
    Woodlands MB, Canada
    349
    Get TuneIn Radio Pro... https://itunes.apple.com/us/app/tune...319295332?mt=8
    It allows automatic tuning to any internet radio station in the world. Set the time you want the station to come on, turn up the volume and make sure TuneIn Pro is running.. It will start playing at your chosen time. It can also automatically record radio programs. Note that you need TuneIn Pro and not the basic TuneIn app which does not have the automatic tuning/recording feature.
  1. Radio Alarm app
    By DontUnderstandMyIpad in forum iPad Apps
    Last Post: 12-10-2012, 04:52 PM
  2. Replies: 0
    Last Post: 05-09-2012, 12:46 AM
  3. Tune in radio/french radio stations
    By Phine00Del in forum iPad Apps
    Last Post: 03-27-2011, 05:16 PM
