Results 1 to 7 of 7
    166704
    Feb 2012
    5
    IPAD 2 missing volume slider
    Hi All,
    I am at my wits end with this. I can get sound from sounds, from dock, from headphones but nothing without anything connected. I have restored the ipad with no apps issue same. I plug in headphones and bing slider appears.. i then changed the headphone jack as per some tips online... same...i then changed the internal docking charger same...I set an alarm ...bing it works..so to recap...i get sounds from sound app / alarm / notifications......sound when docked and with headphones...nothing without headset and the slider disappears...
    any experts out there help someone who has tried to help themselves but failed miserably...;-)
    85546
    517 times
    Aug 2011
    Edmonton AB Canada
    9,720
    Turn Bluetooth off, just in case your volume is being redirected to there for some arcane reason.
    Also go to Settings/Sounds/Change with buttons and turn it off. That disables the volume control for sound effects, and may force it back to controlling your speaker volume.
    We have had this issue in the past and never found a satisfactory solution as far as I know.
    166704
    Feb 2012
    5
    thanks should have said i have tried this numerous times..
    iPad Addict
    260719
    75 times
    Nov 2012
    Niagara-on-the-Lake Ontario Canada
    1,016
    Quote Originally Posted by Williebear
    Hi All,
    Sounds like there might be a problem in the headphone jack. Try plugging and unplugging a headphone plug rapidly many times. See if that clears it up. It seems the contacts in the jack which disconnect the speaker when headphones are in use, are not reconnecting when the plug is removed. A small amount of methyl alcohol on the plug before the rapid in-out may help to clean the contacts. Let us know the result.
    Roy Rob - Niagara-on-the-Lake
    Ontario
    166704
    Feb 2012
    5
    already replaced that and the dock connector....hmm its doing my head in...
    67820
    109 times
    Jun 2011
    Lancashire, England.
    3,050
    Hi, can you give us a list of everything you have tried, it may speed up a solution if we aren't posting things you have already tried.
    64GB wifi ipad2 iOS 6.1.2 (Jailbroken using Evasi0n) : 120GB iPod Classic (Filled with Rock Classics!) : AppleTV 2G iOS 5.0.2 (Jailbroken using seas0npass) : iPhone 3GS 16gb iOS 6.1.2 (Jailbroken using Evasi0n) : iPhone 3GS 32gb iOS 6.1.2 (My Rambling Tool is now Jailbroken using Evasi0n) : iPhone 4 16GB iOS 6.1.2 (Jailbroken using Evasi0n) : iPhone 4S 64GB iOS 6.1.3 (Stock, so I can stream Sky Go)
    166704
    Feb 2012
    5
    ok... #. tried settings / switched off bluetooth
    #change with buttons off
    #. side toggle
    #. full restore
    #. replaced headphone jack(internal)
    # replaced dock (internal)
    with ipad docked there is sound and slider
    with headphone connected there is sound as slider
    tested sounds then ringtones... crystal clear.
    the only thing i can think of is the main board / speaker ( if there is 2 channels going to it)
  1. iPad2 (soft) Volume slider knob missing
    By tpeterse in forum iPad 2 Forum
    Last Post: 01-26-2013, 05:57 PM
  2. Am I missing. A volume control
    By davidtxs in forum iPad 2 Forum
    Last Post: 10-12-2012, 07:33 PM
  3. volume control slider missing on YouTube
    By Dilana in forum iPad 2 Forum
    Last Post: 09-25-2012, 08:53 PM
  4. ipad 3 slider theme need help!!!!!!!
    By ipad3001 in forum iPad Hacking
    Last Post: 09-18-2012, 01:54 PM
  5. volume up button missing pressure/klick point
    By Spielor in forum iPad Help
    Last Post: 09-07-2010, 12:12 AM
ipad 2 missing volume slider
ipad 2 volume slider disappeared
ipad volume control missing
ipad volume slider missing
my volume slider disappeared ipad 2
no volume slider on youtube with ipad
utube ipad volume slider
volume bar missing ipad 3
volume disappeared on ipad
volume slider missing on ipad 2
volume slider missing when playing videos on ipad
youtube and ipad volume slider
