Results 1 to 4 of 4
    271423
    Jan 2013
    CA
    Ipad 2 Jailbroken 5.0.1: Cant exit safemode! Help!
    Ok before the story heres the ipad
    Ipad 2 Jailbroken
    5.0.1
    16gb
    Wifi
    So heres what happened,
    I downloaded call of duty: black ops zombies for ipad,
    I loaded it up and it said low on ram, so i simply killed all apps in the background and rebooted the ipad,
    It took long so i put a charger on it,
    I came back maybe an hour later and it was still in the apple boot logo, i put it into safemode, by holding power + sleep untill the apple dissappeared and
    Held the volume up button until it finally finished booting, and it was in the form of safe mode but didn't say "Exit Safe
    Mode" at the top where the time should be. I opened up cydia and deleated some recent tweaks (about 6) and rebooted it
    It got Stuck on the apple boot logo again and i put it back into safe mode again. How do i exit it! Please help!
    13576
    803 times
    Aug 2010
    Western NY state (USA)
    9,454
    The only way to exit the Mobile Substrate Safe Mode is to reset the iPad (hold both sleep and Home buttons until the white Apple logo appears). I just finished trying it and, while I can see and use SBSettings, doing a respring from there did not work; I was still in the Safe Mode.
    So, try the reset again. But this time - have patience. Let the iPad work to reset itself. Eventually, the white Apple will go away and the Springboard will come back...
    Oh, and Mobile Substrate Safe Mode (the one where you hold the volume up key) doesn't tell you that you're in Safe Mode as the "normal" one does. The only way you know is seeing that you mobile substrate tweaks don't work.
    271423
    Jan 2013
    CA
    When i reset the ipad it gets stuck on the apple and does not go back to the springboard untill i do the mobile substrate safe mode. Last time i left in on for an hour and put it back to mobile substrate mode and reset it again for atleast overnight and it was still on the apple boot logo until i put it back onto the safe mode :/ ill try again throughout the night and let it do its thing! Thanks Marilyn!
    271423
    Jan 2013
    CA
    I have reset the ipad and hooked a charger to it and left it for 9 hours, and no results! What could the problem be!
    16 GB iPad 2
    Jailbroken at 5.0.1
    With Greenpoison
    iPhone 5
    32 GB
    IOS 6.0.1
    Not Jailbroken
  1. Safari & apps repeatedly exit out.
    By Katelin in forum iPad Help
    Last Post: 02-02-2013, 11:44 AM
  2. Replies: 2
    Last Post: 07-21-2012, 04:06 AM
  3. Replies: 2
    Last Post: 12-01-2011, 02:16 AM
  4. My ipad won't exit in DFU mode...please help
    By jieo in forum iPad Hacking
    Last Post: 07-25-2011, 07:59 AM
  5. Can't exit youtube? What am i doing wrong?
    By Fixmy59bug in forum iPad 2 Forum
    Last Post: 03-20-2011, 10:25 PM
exit safe mode ipad
exit safe mode ipad 2
exit safe mode on ipad2 5.0.1
how to exit safe mode in ipad
how to exit safe mode ipad
how to exit safe mode on ipad
how to exit safe mode on ipad 2
ipad 2 cannot exit safe mode
ipad exit safe mode
ipad exit sfe mode
ipad how to exit safe mode
why my jail broken phone says exit safe mode
