IPad2 battery percentage does not update...at all
This is a discussion on IPad2 battery percentage does not update...at all within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Originally Posted by betweenthesedays Just an update. It appears this may be a known issue post 6.0.1 software update. Mine was the second iPad @ ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Moderator
    131244
    1426 times
    Dec 2011
    Regina,Canada
    18,560
    Quote Originally Posted by betweenthesedays
    Just an update. It appears this may be a known issue post 6.0.1 software update. Mine was the second iPad @ the a Genius Bar tonight with the issue. The battery is just fine, it's most likely a firmware issue. They updated/reset my iPad again and if that doesn't fix it then it's probably a hardware issue. 6.0.2 is supposed to fix the problem that caused my firmware issue. Supposedly, anyway.
    iOS 6.0.2 is only available for the iPad mini and the iPhone 5.
  3. #12
    84299
    Aug 2011
    7
    Quote Originally Posted by scifan57
    Correct. He was just speculating about the possibility of a fix when the next update is available for iPad - not saying that it is available now. iOS 6.0.1 is the current version for iPad.
    Today's battery seems to live in opposite land where battery level decreases to 85% before magically recharging itself through the evening culminating in its arrival at 100% when I had to restart the iPad in order to get AirPlay to reappear. Two hours later and it's clear that magic battery is here to stay. Restore (treating as new) and firmware update at the Genius Bar (again treating as new) did not fix it. I'm going to run it down until it shuts off, recalibrate, and see if I can get it working again. I usually get the new update when it becomes available and I don't remember when that was, but it wasn't last week when my problems first appeared which makes it hard to believe it would be software/firmware/update related.
    Still, just shy of two years and this is my only complaint - it's worked flawlessly up until this point. I guess I can't complain too much.
  1. Icon next to Battery percentage?
    By michali in forum iPad General Discussions
    Last Post: 05-22-2012, 02:02 PM
  2. What is your battery percentage?
    By Dking139 in forum iPad General Discussions
    Last Post: 08-05-2011, 11:53 AM
  3. Replies: 1
    Last Post: 07-20-2011, 12:19 PM
  4. Remove Battery Bar / Only Show Percentage With Bolt
    Last Post: 05-31-2011, 01:13 AM
  5. Who turns off their battery percentage meter?
    By 32gb3gwifialicious in forum iPad General Discussions
    Last Post: 01-26-2011, 11:15 AM
ipad 1 battery percentage not changing
ipad 2 battery bar not moving
ipad 2 battery percentage
ipad 2 battery percentage not changing
ipad battery percentage not changing
ipad battery problems not showing correct charge
ipad charging percentage not increasing
where is the battery percentage on the ipad 2
