iPad Charging Issue
This is a discussion on iPad Charging Issue within the iPad 1 Forum forums, part of the Apple iPad Discussions category; well i have an iPad 1 that i've upgraded to IOS 5.1.1 after the update few days my iPad started to show me this msg. ...
Results 1 to 9 of 9
    257420
    Nov 2012
    iPad Charging Issue
    well i have an iPad 1 that i've upgraded to IOS 5.1.1 after the update few days my iPad started to show me this msg. "Charging is not supported with this accessory" buying a new cable is not a solution, cause eventually, the new cable starts failing again, so does that means to buy always a new cable every time it decides to crash? Definitely is the iPad that doesn’t work at all. A real solution is needed and many users are still expecting that from Apple. I’d searched a lot in the internet with this issue and all the answers are the same every where all over the net “buy a new cable” bull****. I WANT A NEW SOLUTION!!
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,240
    Hi There--understand that you are having frustrations with this. So just to be clear, you have switched to a new/or different charger and you are still getting this message? Have you also tried to use a different power outlet to see if this helps?
    257420
    Nov 2012
    i have tried to charge it with another different charger and different power source and nothing solved
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,240
    Quote Originally Posted by MrMazen View Post
    Have you tried the original cable the iPad came with ?
    257420
    Nov 2012
    Yeah sure i used to use the original cable . that problem came after the upgrading to IOS 5.1.1 before the update my iPad was working fine!
    iPad Wizard
    49745
    370 times
    6,591
    I'd try searching the forum or googling for existing threads. If you don't find leads that way, it might be a hardware prob that coincided with your upgrading to 5.1.1.
    I've not encountered any charging prob in the months since upgrading either my iPad 1 or my husband's iPad 1 (which we recently gave away) to 5.1.1. And we use about six to eight diff chargers, between homes and cars.
    53292
    May 2011
    44
    Make sure you are using the original length cable. I used a longer one and get the same message you do.
    J
    258345
    Nov 2012
    Been having same problem our son broke the original cable, tried different ones keeps saying not supported but then will charge for a min he stop and keeps doing this using original charger but different cable, would just buying a OEM cable fix this?
    Moderator
    131244
    607 times
    Dec 2011
    Regina,Canada
    14,410
    Quote Originally Posted by nintendo guy
    Try making a Genius Bar appointment at an Apple store. Have them try one of the genuine cables. If it works, you're fine. If it doesn't work, there's likely some kind of hardware issue.
  1. Ipad charging issue
    By printmeitadam in forum iPad 2 Forum
    Last Post: 08-16-2012, 12:19 PM
  2. Charging Issue
    By jschlis in forum iPad 3 Forum
    Last Post: 08-14-2012, 08:06 AM
  3. Battery charging issue
    By ianb59 in forum iPad 3 Forum
    Last Post: 07-13-2012, 05:58 AM
  4. iPad2 charging issue
    By sivaram4110 in forum iPad 2 Forum
    Last Post: 03-20-2012, 07:41 PM
  5. iPad 1 not charging issue resolved
    By johmr in forum iPad 1 Forum
    Last Post: 02-04-2012, 01:01 AM
charging is not supported
charging is not supported with this accessory ipad1 5.1.1
ios 5.1.1 charging not supported
ipad 1 charging problems
ipad 5.1.1 charging not
ipad charging not supported
ipad update 5.1.1 not charging
ipad1 charging is not supported
iphone 4 charging is not supported with this accessory
