Ipad1 has no sound except while using earbuds
This is a discussion on Ipad1 has no sound except while using earbuds within the iPad 1 Forum forums, part of the Apple iPad Discussions category; Have tried double clicking home button but there is no sound bar unless the earbuds are plugged in. Help...
Results 1 to 5 of 5
    224531
    Jul 2012
    45904
    11 times
    Philippine
    595
    Quote Originally Posted by reikodr2292
    After double clicking, swipe from left to right (bottom screen). You should see the sound bar.
    242018
    Sep 2012
    Did you ever get a response as I have the same problem
    85546
    472 times
    Aug 2011
    Edmonton AB Canada
    9,464
    Try Settings/General/Reset/Reset All Settings for starters. Let us know if that works. If not we can try some other stuff.
    Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro |
    85546
    472 times
    Aug 2011
    Edmonton AB Canada
    9,464
    Here's another thing you could try. Plug earbuds in. Set volume to wherever you like it. Then with music still playing, remove the earbuds, and turn the volume up. The speaker volume is independent of the earbud volume, although it is controlled with the same switch.
    I just checked and the volume will mute when you pull out the earbuds. It's worth a try. Also, make sure Bluetooth is turned off, because THAT has an independent volume too.
    In this case, you have to KNOW which volume control is active.
  1. Earbuds playing on one channel only
    By elmofranken in forum iPad Help
    Last Post: 05-28-2012, 12:37 PM
  2. Earbuds with noise cancellation microphone
    By Intranetsites in forum iPad General Discussions
    Last Post: 01-15-2012, 06:18 PM
  3. Hello!!! I need some help with earbuds...
    By Zoie1luv in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-05-2011, 04:40 AM
  4. Earbuds or headphones
    By Gapeach441 in forum New Member Introductions - Site Assistance
    Last Post: 08-25-2010, 08:28 PM
  5. Bluetooth earbuds for Ipad
    By Louisg in forum Off-Topic
    Last Post: 06-20-2010, 02:43 AM
ipad 1 audio not working
ipad 1 no sound
ipad 1 sound not working
ipad has no sound
ipad1 no sound
no sound bar on ipad
no sound ipad 1
no sound ipad1
no sound on ipad 1
no sound on ipad1
sound not working on ipad 1
why the sound on the ipad 1 not work?
