Results 1 to 9 of 9
Thread: USB Connection
    5736
    Jun 2010
    Houston TX
    25
    USB Connection
    I know there is no USB port on the Original IPad, but I need to interface with a USB headset (mic and headphones) as provided by Rosetta Stone. Is there an Apple connector-to-female USB cable to allow this? There is, of course, an app to allow Rosetta Stone on the iPad and iPhone. Thanks!
    newt0nsbump
    Moderator
    131244
    732 times
    Dec 2011
    Regina,Canada
    15,112
    Quote Originally Posted by newt0nsbump
    newt0nsbump
    I'm afraid that there is no way to connect a USB accessory to your iPad. Maybe finding a headphone/mike that plugs into the headphone jack will work.
    Supporting Vendor
    154
    21 times
    Jan 2010
    311
    Quote Originally Posted by newt0nsbump View Post
    newt0nsbump
    As powerful as the iPad is, it is not compatible with desktop apps like Rosetta Stone, so aside from not being able to connect their headset, you will not be able to run the application directly on the iPad either.
    Rosetta Stone does offer an iPad "application" that will let you access their "TOTALe" course though:
    TOTALe Course HD for iPad on the iTunes App Store
    But aside from providing only access to their content over a working internet connection, it also requires you to sign up for a monthly subscription service in order to use it.
    5736
    Jun 2010
    Houston TX
    25
    I know about the iPad app since I am going to use the Totale option but I need to be able to speak and hear through a headset to make use of it. This is apparently no problem iPad 2 and 3 and despite the lack of a direct USB connection I cannot believe there is no way to interface with an external headset.
    Supporting Vendor
    154
    21 times
    Jan 2010
    311
    What about a bluetooth headset. It will not be Rosetta-certified, but it should do the trick.
    guo
    guo is offline
    11245
    Aug 2010
    I'm sorry, I can only think of bluetooth equipment
    228482
    3 times
    Jul 2012
    38
    Am I missing something here? The original Apple headset works just fine on iPad 1, ear piece and mic. I've used it a thousand times on Skype calls and it works perfectly.
    229990
    Jul 2012
    16
    am i missing something as well??????
    there is a Ipad usb dock converter it converts the dock clip to usb but the ipad was designed with a headset and mic jack in one port the headphone jack on the ipad also has built in mic functions so why bluetooth???
    45904
    11 times
    Philippine
    595
    I think the idea of a Bluetooth is to make things simpler. It doesn't matter if it wired or not. Just a preference for the owner.
  1. Wi-Fi connection
    By anneUK in forum iPad 2 Forum
    Last Post: 04-17-2012, 06:37 AM
  2. ipad camera connection kit drops connection
    By stingray1059 in forum iPad Help
    Last Post: 12-25-2011, 06:19 PM
  3. USB 3G Connection?
    By bho in forum iPad General Discussions
    Last Post: 03-26-2011, 09:48 AM
  4. connection to MAC
    By jakki in forum iPad Help
    Last Post: 09-19-2010, 09:18 PM
  5. Replies: 3
can i use rosetta stone usb headphones with ipad through camera connection kit
female usb to apple connector
rosetta course ipad hack
rosetta stone bluetooth
rosetta stone headset for ipad
rosetta stone headset will not plug into ipad
rosetta stone headsets for ipad
rosetta stone ipad hack
rosetta stone ipad headphones
rosetta stone online access hack
rosetta stone usb headphone adapter
usb to apple connection female
