batteri problems
This is a discussion on batteri problems within the iPad 1 Forum forums, part of the Apple iPad Discussions category; Hi I have a ipad 1 gene, now I have had problems with it for long. When I try to charge it (with the original ...
Results 1 to 4 of 4
    173867
    Mar 2012
    batteri problems
    Hi
    I have a ipad 1 gene, now I have had problems with it for long. When I try to charge it (with the original charger) I just get the plug connector by the battery, and it will not charge. When connected to the charger, turn it on and off by themselves, have tried to restore it, but did not work either. thought it was a thing with the update to ios 5.0. Now that I have innsatalert 5.1 does not comply with this error. Hope someone can help me with it.
    Thank you
    Closed frustrated ipad use
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Hello and welcome to the forum!
    Please take a look at this Apple support article on Battery Management - an Apple recommendation is to allow the battery to fully discharge about once a month which re-calibrates charge monitoring of the battery.
    Also, if available (friend or Apple store?), try another iPad charger (you'll need one that outputs 10 W like the original); if you do visit an Apple store (or another place that can test your battery/charger) further in depth testing can be done.
    Finally, if the battery might need to be replaced, review this other Apple support article on Battery Replacement - the 'new' iPad might be another consideration, if you do need the battery replaced? Good luck and please post back your results -
    175599
    Mar 2012
    asia
    5
    Quote Originally Posted by Wanted56 View Post
    Hi
    Thank you
    Hello,
    Well i also update my Ipad,
    But i didn't found any change with my battery..
    175892
    Mar 2012
    Check your cord, is it kinked at the place where you plug it in? I have had to replace mine three times (FREE from the store).
  1. 4oD problems
    By DC1962 in forum iPad Help
    Last Post: 03-09-2012, 07:29 AM
  2. Problems in JB
    By smaq391 in forum iPad Hacking
    Last Post: 01-23-2012, 04:00 PM
  3. Ios problems
    By bennyh in forum iPad OS
    Last Post: 10-13-2011, 04:11 AM
  4. 2 problems
    By beno in forum iPad Help
    Last Post: 09-27-2011, 06:46 PM
  5. AOL Problems
    By Figment49 in forum iPad FAQ
    Last Post: 05-26-2011, 11:20 PM
can ipad turn themselves off while on charger
ipad 1 battery replacement
ipad charger is kinked
