I am having issue with ipad charging. I bought a universal ipod/Iphone/ipad cable and it worked for a day and now it say not charging. I used a friends ipod touch charger and it says charging assecory not supported.
Any ideas. Thanks.
This is a discussion on ipad will not charge within the iPad 1 Forum forums, part of the Apple iPad Discussions category; I am having issue with ipad charging. I bought a universal ipod/Iphone/ipad cable and it worked for a day and now it say not charging. ...
Any ideas. Thanks.
That is because the charging block the thingie that plugs into the electrical plug socket has to be for a iPad and not an iPod. From what I read there is more power sent to the iPad using the charger that was made for it.Originally Posted by Tommyandamanda21
That is why an iPad will not hare when hooked up to a computer where as an iPod/iPhone will charge.
Go to eBay and search for a charger means for the iPad you may want to even purchase the charging cable as well.
Ok I just plugged in my iPad using my charger for my iPhone 4s and the indication that the iPad was indeed charging
So the charger might not be any good.
I have had to replace charging blocks before.
Sent from my IPAD 1st generation. WIFI only. 64GB
