a problem with photos
This is a discussion on a problem with photos within the iPad 1 Forum forums, part of the Apple iPad Discussions category; when i copy a batch of pictures to my ipad the previous batch is deleted or at least it disappears. can i have all batches ...
Results 1 to 7 of 7
    152433
    Jan 2012
    israel
    when i copy a batch of pictures to my ipad the previous batch is deleted or at least it disappears. can i have all batches of pictures saved on the ipad and if yes how?
    2888
    48 times
    Apr 2010
    Fort Wayne, IN
    1,220
    Hello idodis, welcome to the forum.
    When you 'batch copy' photos from your source to the iPad, you are doing this via the iTunes synch? If so, you need to create new folders in your source file. For example, if you used a folder titled: FileA, this FileA will have a similar folder on the iPad. However, if you batch from source back into the same file on the iPad, you will wipe out all those files already there and replace with new.
    So the solution is, at your source create a FileB and then when you sync, FileB will appear as FileB on your iPad. I hope this helps you.
    152433
    Jan 2012
    israel
    i will try. thank you. idodis
    152433
    Jan 2012
    israel
    did not work. i copied a file of photos from my computer section d my pictires. i saw it in albums on ipad. then i created another fine in section c desktop with pictures i moved from the previous file (my pictures) mentioned above. i synced. nothing was left on the ipad - not the old ones not the new ones. also once they are on the ipad i do not succeed to save them. i must be doing something totally wrongly. can you go with me step by step. thank you and sorry to bother you.
    2888
    48 times
    Apr 2010
    Fort Wayne, IN
    1,220
    Hello idodis! I am away from my PC, so it is hard for me to walk you thru the process of synching your source's files to your iPad. I hope that someone else will see this thread and assist you with this how to directions. I will check back here when I get back to my PC and walk you thru the process. In the mean time, go play angry birds!
    17825
    Oct 2010
    Florida
    79
    Make a folder on your PC and identify it in iTunes as the folder you want to sync with. Tell iTunes to include subfolders. On your PC make subfolders in your main folder you identified in iTunes that you place pictures in. When you add new pictures you can add them to the main folder or to the subfolder. Each subfolder will show up as a new photo album on your iPad. They will all sync.
    152433
    Jan 2012
    israel
    this time it worked well. thank you. i get things pretty fast - you only have to explain them to me very slowly. thanks a lot.
  1. Problem with Photos iOS 5
    By Peter_Izn in forum iPad Help
    Last Post: 01-12-2012, 09:45 PM
  2. Syncing Photos Problem!! Help?
    By Padi in forum iPad 2 Forum
    Last Post: 10-16-2011, 03:24 AM
  3. Problem with Photos app on iPad 2
    By Maggie2011 in forum iPad Help
    Last Post: 07-24-2011, 10:21 PM
  4. Problem Synching Photos
    By pdmike in forum iPad General Discussions
    Last Post: 01-24-2011, 12:54 PM
  5. Very perplexing problem with photos
    By jseltzer in forum iPad Help
    Last Post: 04-29-2010, 09:58 AM
ipad photos disappear when add more
ipad photos disappear when i add more
photos disappear after syncing in itunes
problem with photos on ipad
problems with pictures diasppering on ipad when i copy new ones from pc
syncing photos to ipad disappear
when i synch new folders on my itab the old ones are dissapearing
when syncing ipad albums previous ones disappear
why are my pictures disappearing when i sync a new folder
why do photos disappear when i sync my ipad
why ipad disappear in photo
wy do my pictures disappear when i sync new ones to iphone
