Help need * key!
This is a discussion on Help need * key! within the iPad 1 Forum forums, part of the Apple iPad Discussions category; I just got this IPAD and was trying to add my gmail. It requires my password which has the "*" key. Is there a secret ...
Results 1 to 3 of 3
    132203
    Dec 2011
    Ontario, Canada
    Help need * key!
    I just got this IPAD and was trying to add my gmail. It requires my password which has the "*" key. Is there a secret way to type the *
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Hi QC - welcome to the forum!
    The * key takes a few steps - from the standard typing menu, select the '.?123' menu, then look to the left and choose the '#+=' menu which will bring you to plenty more symbols, including the asterisk key - let us know if this works for you - shortcuts can also be setup so another possibly easier option than paging through all of these menus - good luck!
    132203
    Dec 2011
    Ontario, Canada
    Quote Originally Posted by giradman View Post
    Your awesome!! Thanks. I don't know why I didn't think to try any of those keys...DUH!
asterik symbol ipad
asterisk key ipad
asterisk key on ipad
asterisk on ipad
i pad 3 asterisk
ipad asterisk key
what key you use for as asterisk on an ipad
where is an asterisk on an ipad keypad
where is the asterisk key on the ipad
where is the asterisk on ipad
